Question about Panasonic NN-P295SF Microwave Oven
Panasonic nnsd 780s wont shut off
Must pull plug to turn off
Panasonic 1250w genius senor inverter less then a year old. Control panel lights up, works.microwave itself does not, control panel shuts off in a few seconds
When a Panasonic Inverter Microwave shuts off after a feew seconds, it is either a bad inverter which is the quite expensive circuit board that powers the magnetron that puts out the microwave energy, or a bad magnetron, Or BOTH typically this would be a costly repair, But since it is still under warranty. You need to find a Panasonic warranty service provider in your area. If it is a counter top unit, you may have to take it to them for repair.
Jul 05, 2017 | Panasonic Microwave Ovens
Panasonic microwave began arcing and now shuts off after a few seconds
Your wave guide cover and magnitron need to be replaced.
Apr 10, 2012 | Panasonic Microwave Ovens
On our Panasonic the genius sensor 1200w microwave the bulb burned out so replaced. After replaced turned light switch on both bulbs turned on and right away one bulb burned out and now the switch will not...
Mine burned out within a month. Probably due to the poor design of the machine which forces you to slam the door to get it to shut.
My biggest concern is the under counter lightbulbs it has burned out in my kitchen over the last year. I wonder how much leaking this thing really gives off. Moving in a few weeks and will be throwing this cancer machine out.
Sep 09, 2011 | Panasonic NN-H764 Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
I cleaned it now it won't work, it's not showing the clock, so wondered if it just needs clock reseting
what did you clean it in??? the dish washer???? some times if the plug is removed on an older unit or the power turns off, they just wont start up again,,, its a fult with the micro chips in the computer, the suden surge of power when switshed back on just blows it up,,, iv lost at least 3 in this way
you could try pulling the plug out again but its not very likely to get it working again the real problem is they just dont build in a soft start on them now, so if unpluged then switched back on the computer get a wopping big smack of power that just blows is socks off,, like i sead, i lost 3 evey time the power was cut off they died on me
Oct 21, 2009 | Panasonic NN-T888S Convection/Microwave...
Turntable wont stop turning, even when not in use
The turntable is a seperate intenty from the microwave itself, I would presume that the switch that turns off the turntable when the door is opened needs replacement.
Feb 28, 2009 | Panasonic NN-H965 Microwave Oven
Panasonic microwave 1200
This model uses an inverter to produce high voltage. That symptom is an usually indication of a problem with the inverter or a bad magnetron. I do not recommend that a person without training and experience ever work on these models. You should be able to locate a Panasonic-authorized servicer here: http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 I would mention the exact symptom when you call so the technician can bring a new inverter with him when he comes out to repair it. Might save you having it pulled into the shop. Good luck!
Sep 19, 2007 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
22 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
