Question about Westinghouse Ovens
Timer keeps buzzing westinghouse - Westinghouse Ovens
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
A SMALL BUZZING IS GOING ON AND CANT SHUT IT OFF ALSO OVEN HASENT BEEN USED IN YEARS TURNED ELECTRIC OFF BUZZING WENT OFF
Check to see if there is a switch for an open or not properly closed oven door. Could be stuck in the wrong position.
Nov 09, 2015 | Ovens
My electrolux EOU43002X oven bottom fan recently stopped. it also coincided with a buzzing from the timer panel. I replaced fan motor but timer wont work and the buzz still there when the timers tried
According to the convection fan which does not work, I suggest checking the main oven selector, wiring and convection fan.
According to the timer you should first set the time and then verify the correctness the timer relay. If relay is open than completely oven will not work.
Dado
Sep 08, 2015 | Electrolux Ovens
My daughter turned the timer but when it got to zero and it buzzed....it never stopped buzzing. It is still buzzing 10 hrs now! What can I do?
unplug your oven. sounds like you need a new timer. the relay is not releasing . cause the timer wont let it
Jun 19, 2011 | Kenmore Ovens
Westinghouse oven timer keeps turning the oven off
It sounds like the timer is set you will need to press the cancel/stop buttton, and this will clear the display.
Nov 15, 2009 | Ovens
Zanussi oven timer buzzes at 20.00 then resets to 12.00
Gave up and bought a new timer module for £66 from espares. Timer board has microscopic components so even if you knew what was wrong it wouldn't be fixable.
Sep 22, 2009 | Zanussi ZBF360 Electric Single Oven
Westinghouse Freestyle 668 oven not doing anything , just blinkin
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Apr 20, 2009 | Ovens
Westinghouse 745 wall oven
First thing, remove the plug from the wall power for at least 10 minutes, maybe even thirty minutes and allow it to reset........ if that does not work write me at wbwill@sbcglobal.net and give more model info so I can investigate for you or check out a volunteer site, allexperts.com and you will find me there also.
Nov 10, 2008 | Ovens
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
Ovens Logo
82 people viewed this question
Top Westinghouse Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Westinghouse Oven Expert? Answer questions, earn points and help others
