Question about Miele s558 Silver Moon Vacuum
My mile silver moon won't power on - Miele s558 Silver Moon Vacuum
Miele silver moon vac model s558 serial number nr57365268 what year?
I think it was made in 2008, I found a phone number 1-800-221-8227, maybe they can confirm
Aug 23, 2014 | Miele s558 Silver Moon Vacuum
Miele Silver Moon Losing Suction Power
That is possible, also check for a.m. exhaust filter off the motor. Usually a very fine filter to stop dust that gets past the bag. May just need to open it up and clean out the accumulated debris.
May 02, 2013 | Miele s558 Silver Moon Vacuum
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
MIELE Silver moon turns off after about 10 minutes of using. If I press the "+" button on the handle, it'll turn on again and start up again. Is this an overheat thing or a hose thing?
That sounds like a hose issue, but to make sure it's not an overheat issue I would recommend ensuring that the hose, wand, and dirt tube through the power-head are all clear and free of obstruction. Also try raising the height adjust on your power head: if you have it set too low, air can't move through the carpeting and therefore it will overheat the motor and also not clean as effectively as it could. If all of these things check out, you will have to replace the hose with an SES-125A, but once you've done this you will not have the issue again. Cheers! -R
Aug 03, 2011 | Miele s558 Silver Moon Vacuum
Will not start, will not reset
I have a Silver Moon S558, when I turn it on the power light comes on and a few secords later the red warning light comes on. What is causing the vacuum not to work? One day I was vacuuming, turned it off and a few minutes later went to turn it on and nothing, but these lights turning on. Is there a fix?
Mar 11, 2011 | Miele s558 Silver Moon Vacuum
I just bought a Miele s558 Silver Moon, seems like
good vacuums bags are very expensive and parts too
return it
May 11, 2010 | Miele s558 Silver Moon Vacuum
I just bought a Miele s558 Silver Moon, seems like it's from 2000 or so. If it's in good condition, can I expect this machine to last another ten years? Or would it have been better to buy a lower end...
Greetings from GoVacuum,
Ahh, the Miele Silver Moon model S558i. This is great model that I know a lot about because I actually own this exact model. I have had my Silver Moon now for going on 10 years, with almost no problems. The motors in the Silver Moons are excellent, and should last 20 or 25 years without problems. This particular model did have one major problem however. This is the first model that Miele put the suction controls in the handle of the hose of the vacuum, allowing the user to easily adjust the suction setting with fingertip controls. The problem with these models is that static electricity (usually happens when vacuum carpeting) causes the hose to shut down the power to off. You can be in the middle of vacuuming, and all of a sudden the vacuum will turn off. You can easily turn back on the vacuum with the push of a button, but it's irratating for sure.
Miele did come up with a solution for this problem with a newly redesigned hose, part number SES125-3. Since this new design has come out I haven't had a single issue with my hose. The way you can tell if you have the old or new hose is by the numbers (or lack of ) on the different suction levels. If your hose goes up to 1100 Watts, then this is the older style hose. If you're hose simply has a minimum to high setting with no numbers at all on the hose, then this is the redesigned 125-3 hose.
If you have the older style hose, I would get the dealer that sold you the vacuum to exchange the old hose for the new hose, you definitely don't want to have to buy that new hose ($150+). If you have the new hose, then I would say stick with the Silver Moon over the newer Miele models, in my opinion the Silver Moon is one of the most durable models that Miele has ever made.
The only other thing you need to be careful of is the cord reel. When you are retracting the cord reel, it's best to kind of guide the cord back in, and take it slow rather then just stepping on the cord rewind pedal. The cord reel can sometimes be touchy, especially if you are rough with it. If you're careful with it, you should never have any problem with the vacuum cleaner as long as you change the filters on a regular basis as well as the bags.
I hope this helps, if you have any further questions, please feel free to contact me at chris (dot) jones (at) govacuum (dot) com.
Thank you,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Miele s558 Silver Moon Vacuum
My Miele Silver Moon "Reset" light is blinking. What do I do?
Ahh yes, the Silver Moon. One of Miele's best made vacuums ever! So good that out of all the different vacuums that I could of chose for my home, the Miele S558 Silver Moon was the one I chose.
When you're Reset button is flashing, this simply means that it's time to replace the HEPA filter on your vacuum cleaner. Miele included this feature on their upper end models to alert the user when their filter needed to be changed.
The Miele Silver Moon uses Genuine Miele S-Class HEPA Filter for S300i/S600i, and Miele S7 Uprights. Miele Part # 04854915 (replaces 04854911) Which can be purchased from GoVacuum for $52.95 with free shipping.
Once you have installed the new HEPA filter, simply press down on the flashing Reset button to restart the 50 hour internal timer inside. Miele recommends to replace this filter after every 50 hours of vacuuming.
If this answer was helpful, please click on the helpful Thumbs Up icons in the top right hand corner of this Solution.
If you have a repair that you would like explained, please check out our Q & A website, askgovacuum.com.
Thank you very much,
Chris Jones
GoVacuum.com
Feb 19, 2010 | Miele s558 Silver Moon Vacuum
Miele silver moon vacuum just quit
Usually this is a problem with the electric circuits in the hose / handle.
Dec 17, 2009 | Miele s558 Silver Moon Vacuum
Miele s558 Silver Moon Vacuum Logo
76 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
