Question about Sony Dvcam DSR-PD150 DV Digital Camcorder
Distorted pixelated image on right side
This is not visible on recording and only happens in a vertically banded area on the right 3rd of the screen area. It has been intermittent and not fixed with multiple head cleanings.
  • 221 Answers
Re: distorted pixelated image on right side
Pixelation on the right side of the picture is an indication of a misaligned tape exit roller.  head cleaning won't fix it; it has to be done by a technician.
Posted on Oct 19, 2007
0 characters
3 Points
Pv-l453d no picture from lens to lcd blank screen ?
Your device has the option buttons on which to select recording by observing the process from the user observation scopes. One option only could be observed at the recording session. On the other hand, disabling the option of observing a recording session on the scope lense automatically displays the recording session on the visible lense LCD screen area.
Manipulating the Camcorder is from the option buttons located along the sides of the camera. A switch on the menu area should make that experiece achievable.
Dec 02, 2010 | Panasonic Palmcorder PV-L452 Camcorder
Canon GL2 mini DV Camcorder
well it seems that the recording head was damaged or in the stage that it was not functioning normally, the best way is to replace the recording head of the device..
Jun 26, 2008 | Canon Video Cameras
When recording and playing back the view screen is distorted with alternating lines.
If there is no problem when you play back on a different camera or computer, then the fault concerns LCD ribbon cable or lcd controller circuit on main pcb.
If the recorded image is also distorted on computer and different camcorder, then you have a faulty ccd sensor.
Also wiring problem and pcb fault sometimes can cause ditorted picture, in that case the problem is usually a kind of dirturbance and does not happen all the time.
Jun 24, 2009 | Canon ZR830 Mini DV Digital Camcorder
Picture Image Becomes Blury When Recording
i had the same problem i just gave the camera a good smack and it was all good. lol
Apr 19, 2009 | Sony Handycam DCR-TRV38 Mini DV Digital...
LCD Screen and view finder are distorted
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Good luck.
Nov 23, 2008 | Canon ZR85 Mini DV Digital Camcorder
In Camera mode, only streaky vertical lines visible on screen
Its a fault with many of the canons,
they have NOT recognised it,
but you can get it fixed free by a third party company
(cant remember off hand which one soz)
Funny how they do it for free,
as if canon are paying them so they dont have to own up !!!
Feb 26, 2008 | Canon MV700 Mini DV Digital Camcorder
Distorted Image
if it records the distortion then i suspect the guides are out of adjustment or your capstand roller is pushing the tape to high on the guides. need to have a profession serviced.
Feb 07, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
Vertical green and brown lines on the viewfinder and LCD
Your camera DCR-HC20 has problem with ccd imager and this part will be replaced. After that camera will show live view to record.
Sony announced free of cost repair scheme for such problem. You will pay shipping charges only $15
Click Sony Support for details.
Jan 09, 2008 | Sony DCR-HC20E Mini DV Digital Camcorder
pixelation on the right side is an indication of misalignment of the exit roller.  don't try to align it yourself unless you're experienced in this repair.
Oct 10, 2007 | Sony Dvcam DSR-PD170 DV Digital Camcorder
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Sony Dvcam DSR-PD150 DV Digital Camcorder Logo
116 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
