Question about Powermatic 1792000K Model PM2000 3HP 1ph Cabinet Saw 50" Fence
Up and down blade crank works hard.
I don't know a lot about it. A friend of mine wants me to look at his saw and help him figure out why the blade cranks so hard. The tilt works fine but the up and down cranks hard. I have not looked at it yet but was hoping you could tell me some things to look for. Is this a common problem. I'm quite sure it isn't dirty because he takes good care of things. It's probably mechanical. Thanks,
Don
    President:
  • 1,489 Answers
Yes, it's common and it's usually because it's dirty (mostly sawdust). It's kinda hard to damage those components, so I'd expect to have to give it a good cleaning and an even better lubrication -- start with WD-40 after cleaning, then a heavier oil like 3-in-1 machine oil. Give attention to all moving parts in this mechanism.
Posted on May 08, 2009
Problems with 10in table saw, raising blade height. Very hard turning. Already clean unit and white grease
Need to know the brand and model in order to help you.
Many have elevating rods that the saw carriage moves up and down on - they get bent and the carriage won't move up and down.
Please post the brand and model and I will do my best to help
Feb 28, 2017 | Blade Saws
Got a dewalt dw321k. Bought it new years ago. Cannot get a blade into it at all. Undone the top but still can't get blade in. Any ideas??????
These t-top blades are not obvious in how they fit, but fortunately they have been around long enough that there are lots of people that can help you. It may be humiliating, but just take the saw to any hardware or home-improvement store and ask somebody there to show you how it works---- or you could save face by leaving your saw at home and just asking for help with one on display! Just about any saw that uses this style of blade (which is most of them now) will work the same way, so you don't even have to find your exact same model. Good luck.
Oct 14, 2012 | Dewalt DW321K Heavy Duty Variable Speed...
Blade won't go up or down. It looks like a
If this is a problem with a sears craftsman table saw, you may be able to downlaod and exploded parts view from the instruction manual, often found at http://www.managemylife.com/
You'll need to have the model number handy. If you can't find your saw, look at comparable models and you may find the mechanism is similar.
Some handles have a pin that must engage in the shaft in order for the handle to actually crank the gears on the trunnion up and down...perhaps that is also missing? I'm afraid without more to go on I can only make guesses, and I'm not that familiar with craftsman saws.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2011 | Craftsman Saws
I have a 12" Ridgid
if it is only 2 months old take it back and get another one. if this not an option try some loctite on bolt
Jun 27, 2011 | Ridgid Reconditioned 12 In. Compound Miter...
I have been given an older bench top bandsaw make is Brico model BS 360 wouls like to know where I can get a copy of the manual for this and the blade length it requires. Thanks for the help
It takes a 70 inch blade. Don't go any wider than 3/8 inch, a 1/4 in blade works well. Get as thin a blade as possible. The 6" wheels can be ******* blades. I had new tires made for mine but have lost the name and address of the source so now I am on a search for those!
You will probably have to get the blades custom made. I get mine made at Island Saw in Victoria BC Canada. Not too expensive.
Apr 04, 2011 | Saws
My Hitachi cj 110 jig saw blade keep falling out I have tried different types of blade What?s the deal with that? I don?t know why someone would put a quick release holder on a blade shaft of a power tool...
WOW everyone really cant figure out the problem??? Take your jigsaw blade and hit it with some coarse sandpaper or a dremel and knock the finish off the edges and sides depending on maker and it willl work just fine. The blade companys put a super slick finish on the blades. not the saws fgault.
Steven Melton
OKC
Jan 09, 2011 | Hitachi CJ110MV D Handle Jigsaw
Mt 18 inch horizontal band saw is not cutting square
Thicker metal shows greater blade / saw adjustment errors. A simple 1/64 or 1/32 wont show much on an 1/8 thick piece of metal when cut.
Those numbers will double quickly as the cutting blade travels through thick metal.
Metal band saws seem to be trickier to adjust and fine tune because the blade seems to be twisted into the roller guides.
The downloaded manual for the saw that looked most like mine at grizzly.com helped my adjustments a lot.
The saw quality is also a factor.
Dec 18, 2010 | Saws
My Bosch 4000 blade will not go down any farther than an inch above the top of the table.I have checked and cleaned all the gear area and can see nothing that is causing it .
First of all, love the saw. As good as portables can be, the 4000 is really great.
Now, just remedied the blade height adjustment problem, here is how:
Unplug saw.
Removed blade....not easy when you cannot raise the blade, flip the saw upside down and remove the plastic shield, turn saw upright and remove blade.
Used my compressor with blower attachment and blasted all of the dust out of the gears and screw rods with saw upright and upside down, bevel saw to 45 degrees to gain more access..
Sprayed quite liberally with silicone spray lube and gently worked blade height adjustment, adding more lube, cranking wheel, more lube....blade adjustment now works like the day I bought the saw.
DO NOT USE WD40 or the like. This will just attract more dirt in a very short amount of time.
We'll see how the silicone spray holds up.
Good luck,
RjW
Jan 24, 2010 | Bosch Electric Table Saws
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | Craftsman 10" Table Saw
Powermatic 1792000K Model PM2000 3HP 1ph Cabinet Saw 50" Fence Logo
82 people viewed this question
Top Powermatic Tools & Hardware - Others Experts
Are you a Powermatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
