Question about Uniden BC346XT Handheld Scanner
My bearcat bc346xt makes no sound - Uniden BC346XT Handheld Scanner
How to reset a uniden bc346xt to factory settings iwould like to program my local police
Scanner Reset to initialize the scanner's memory, turn off the scanner. Then press 2, 9, and Hold while turning it on (It helps if you can lay it flat). The scanner will give you the option 'Restore Preprogram List? "Yes"=E/No="."', if you press 'E/Yes', the scanner reloads the preprogrammed systems. Important! This deletes all programmed data. Easier to Read BC346XT Scanner Manual
here is link to manual
Jul 19, 2017 | Uniden Radio Communications
Uniden bearcat scanner bc142xl manual
Hello, the good news, though, is that all Uniden/Bearcat scanners in the 14X series are nearly identical in features and operation, so you can follow the link below to download/print the manual for the BC148XLT:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC148XLT%20%28Manual%29.pdf
You need adobe reader to read the content.
Good luck
Dec 31, 2012 | Office Equipment & Supplies
Clear the memory of a Uniden BC346XT
Turn off the scanner.
Simultaneously press 2, 9, and HOLD.
While continuing to press these buttons, turn on the scanner.
If you need a manual, you may view it here.
Mar 12, 2012 | Uniden BC346XT Handheld Scanner
I have been all through the Uniden Bearcat Scanners and I cannot find what I'm looking for. I am looking for a manual or instruction for a Uniden Bearcat Scanner that was given to me. The MODEL # is:...
Your can download and print the manual for your scanner, at no cost, here:
Bill B.
Listening in since the 60's
Feb 21, 2011 | Uniden Bearcat Pro PC78LTW 40-Channels...
RESET MY UNIDEN BC346XT TO FACTORY SETTINGS
- Power the scanner OFF.
- Press and hold the 2, 9, and HOLD keys, and power the scanner ON.
The RESET/INITIALIZE routine will take about 20 seconds to complete. When the prompt "Restore Preprogram List?" appears, press E.
Bill B.
Dec 29, 2010 | Uniden BC346XT Handheld Scanner
Bearcat BC144XL Scanner ~ no sound
Try it with an external speaker. The external speaker jack receives the audio from the scanner before it goes to the internal speaker. If the jack thinks there is still something plugged into it, the audio to the internal speaker is interrupted. If the jack is stuck, it may still work with an external speaker.
Aug 30, 2009 | Uniden BC248CLT Base Scanner
How to program a bc 560xlt bearcat scanner. Thanks, Les. lorlick@yahoo.com
hello there: here is a link for you that will help out ok
best regards mike
How to Program a Uniden Bearcat Scanner BC 140 | eHow.com How to Program a Uniden Bearcat Scanner BC 140. Programming a Uniden Bearcat ... How to Program a Bearcat 5 Scanner. How to Program a BC 560XLT Scanner ...
www.ehow.com/how_5009391_program-uniden-bearcat-scanner-bc.html - 57k -
Aug 24, 2009 | Office Equipment & Supplies
Bearcat Scanner BC-9000XLT- need manual please!!!
Was able to find and download an adobe file from a website - http://members.accessus.net/~090/bearcatting.html for the Bearcat BC-9000XLT
Nov 14, 2008 | Radio Communications
Uniden BC346XT Handheld Scanner Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
