Question about Poulan Garden
Poulan pro blower pbv 200 want run unless you have the choke on
Pro pbv 200 runs on half choke and half throttle
4 Suggested Answers
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
2strokeguy
  • 183 Answers
SOURCE: trying to get my poulan
How do you know that the coil is bad? Have you checked it with an inline spark tester? It is very rare for this model to burn up an ignition module.
Please check for spark with an inline tester. If there is no spark with that tester, then disconnect the on/off switch and retest. If there is no spark with the switch disconnected, then indeed the module is faulty.
To access the module, the engine has to be removed from the case. Start on the right side and remove the muffler cover and muffler. This is a good time to visually inspect the cylinder. Look into the exhaust port with a flashlight and look at the piston. If there are scratches/scoring on the side of the piston or cylinder walls, then the blower is probably not worth repairing.
On the left side, remove the air filter cover, then remove the filter base (carb cover). This will expose the carburetor. Remove the 2 fuel lines leading to the carb, and then the throttle linkage and remove the carb. Next, remove the carb mount.
Now, remove the 15 or 20 screws that hold the plastic case halves together. The lower hinged cover will have to be releases before the case will seperate. Once you have the case apart, the engine can be removed. The ignition module is now exposed and can easily be replaced.
To set the proper gap of the new module to the flywheel, use a clean and dry business card. Lay the card across the magnet of the flywheel and place the module against it, then install the screws and tighten up the module. Remove the business card.
While you have the blower down this far, check to make sure the cylinder is tight against the crankcase. This model is prone to having the cylinder come loose and will effect compression.
Reassemble in reverse order. Take pictures as you go to aid in reassembly. If the blower is more than a couple of years old, I would recommend to replace the fuel lines at this time. It will save a repair down the line.
You will need allen wrenches, phillips screwdriver, T15, T20, & T20 torx, a large, clean workspace. This is not a repair for the beginning mechanic, but with patience, it is not too difficult.
Good Luck !
Posted on Nov 18, 2010
rycgl
  • 1545 Answers
SOURCE: Poulan Pro blower PBV 200
I have never used, nor heard recommended Ace synthetic fuel. I do believe in synthetic lubricants, and the fuel may be part of the problem. See if you access the H and L mixture screws on the carburetor and adjust them. Here is how that is done:
http://www.zamacarb.com/tipspage.html
Posted on Sep 02, 2011
Why does a leaf blower keep stalling after a period of use?
Ignition coil may be getting too toasty. Full throttle for 10 minutes.. yeah man no one does that. If factory calls for 50:1 gas/oil mix then richen it up to 40:1
Aug 21, 2013 | Poulan Garden
How to change fuel lines in poulan pbv 200 blower/vac
im not familiar with those but donyboy73 on Youtube may be able to help. he does a lot of small engine work
Aug 07, 2012 | Poulan Garden
New poulan pro 25cc chokes out after if I give it full throttle. Runs ok except it wont stay running on full throtle.
I find with my Poulan Pro that you need to let it warm-up abit before applying full throttle, I live in Upstate NY where the weather has bee great lately,however, it stalls easy ..I mix 1-pint of 3 stroke oil to 1-gallon of gas for my weed eater and have no problem
Nov 05, 2011 | Poulan 25CC Gas BlowerVac
Poulan Pro blower PBV 200 when it runs will only keep running on half-choke. I have had the carb serviced every year by a shop who said its the ethanol thats gumming it up. I switched to Ace synthetic...
Sep 02, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
What is the gap setting on coil for poulan pro pbv 200 le
It should be 0.010.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 05, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What type spark plug for the Poulan Pro PBV 200 LE
Sep 05, 2009 | Poulan Garden
Weedeater will not run with choke open.
check your air filter,, and try if do the same thing you have to clean carb. out,, if you dont how just ask me,, thanks hope this help you
Sep 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Will not run unless half choked.Will not run above idle speed.
It is a carburetor problem. The easiest thing to do is replace the carb. If you can do that yourself, post the model # of the blower and I'll tell you the part # of the carb. Otherwise, you will have to take it to a shop
May 31, 2009 | Poulan Garden
Garden Logo
24 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
