Question about Simmons Kids Furniture
Drawers don't line up - Simmons Kids Furniture
Jfd2589kes
Locate and check the valve that feeds water to the icemaker.
Jul 04, 2017 | Refrigerators
How to insert a freezer drawer
Try lifting up on the drawer while trying to insert the drawer in the track
Mar 13, 2013 | Freezers
I'm wondering if I should get more shelves or more drawers in my bathroom vanity
I'm a drawer's person - I love drawers since you can pull them out and don't have to bend every time, like you have to with shelves. I would lose all the shelves and have only drawers. From the designer's perspective, I find drawers are better looking than cabinets.
May 29, 2012 | Furniture
Deli drawer
You don't say brand or size but normally if you remove drawer and shelf above it, unless clips are broken(you can order new) install the clips, install shelf and install drawer that no longer falls down.
Joe Don
May 25, 2012 | Refrigerators
Freezer is Frozen shut
Try unplugging the freezer and leave the door open for about 30 to 45 minutes. Don't forget the door is open and plug the freezer back in. Set a timer in the kitchen so you don't forget. Once you can open the drawers look inside the freezer sides to find the controller. Most models have turn dial inside.
Mar 07, 2012 | Siemens Freezers
Electrolux front load washer leaks from soap drawer
This is a common problem with front loaders. Probably poor design.
Jun 23, 2017 | Electrolux AWF 1435 Front Load Washer
Drain in fridge is clogged - ice formation under crisper drawers
We have cleared / de-frosted the drain twice and it keeps freezing up, causing the accumulated ice problem to recur. Should the freezer settings be changed?
Aug 13, 2009 | Sub-Zero Bottom Freezer Refrigerator
Need to take off u-line 2075 drawer refrigerator doors - how?
Hi
Frost in u-line drawer dwrr models happens because of 3 things. The most common is that the drawer wasnt sealing properly. At the ends of the slides you see a white plastic end. This is called door closers. Remove your drawers,Unplug the top drawer. Then remove the closers on all slides. Take a small screw driver then push on the top of the slide. You should see a piece of the closers. While pushing down pull the ends out.You see the hook and spring, sometimes the hooks get off track and keep the drawer from closing. By keeping them out this should help. Also if you have vegetables keep them in sealed containers. The 3rd thing is you have the display set at 34 and this will cause the unit to run 100% of the time. Recomend 36 degrees.
Jan 17, 2009 | U-Line Echelon Series 2075DWRRSS...
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
Furniture Logo
43 people viewed this question
Top Simmons Kids Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Simmons Kids Furniture Expert? Answer questions, earn points and help others
