Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Sony 60in Grand Wega Channel Guide comes up/Screen goes Blank
Hi, I have direct tv and the channel guide will come up on the screen but when I select a channel the screen just goes blank(black). I replaced the bulb about a month ago, so its not that. All the other tv's in the house work fine so I am not sure if this is a TV problem or a Direct Tv problem. Thanks for your help.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
U may have a bad cable box ( drectv) try a dvd player on the tv if it work fine that means u have a bad cable box ( drectv)
Posted on May 08, 2009
WHAT are the causes BLACK SCREEN
Additional information is necessary to suggest a solution. For exemple, your screen is black or grainy when you select a channel. Please let us know to try helping you.
Thanks,
Sully
Jun 16, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Clock will not set. Channel Guide will not
The TV Guide On Screen guide will not appear if you connect the unit to your television using composite or S-Video cables and the progressive scan option is selected.
Jul 24, 2010 | Sony DHG-HDD500 400-Hours Video Recorder
Dynex flat screen- cogeco box- guide works then goes blank
Not the remote.It the Cogeco box.The box data's it out of dated,some time this happen.Unplug the Cogeco box about an hour,replug the box.Let it update it software.Goto the tv setup goto CH. rescan it again,all the tv channel should be back.
Jul 09, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
My sony wega 55'' tv screen goes blank including the sound and then comes back on a minute later. When the tv is first turned on the green light blinks 11 times
same thing is happening to me.....i chatted with a sony "expert" on sony's website he told me to use different inputs for the sources, im like listen pal, this is happening on hd channels also, where else can i plug the antenna? no response from the expert lol, but im still looking for an answer
Dec 23, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Sony trinitron wega kv-36fs200 36' tv is missing green color
sounds like a major fault with the line output transformer/power board. if no green on screen, tube is on it's last legs. Advise to scrap, not to repair, cost in excess of £200
Oct 23, 2009 | Televison & Video
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
