Bad color The color is bad. It is mainly reds and blues for the color. The picture isn't too bad. Can this be fixed?
  • 8,617 Answers
Sounds like youre describing a phillips that needs the CRT coolant replaced. Whats the model number of your set?
Posted on May 08, 2009
No red in color power went out and can not get a good picture
Try replacing the cables you have hooked up to the T.V. or making sure they're all connected properly. Also, try unplugging the T.V. and plugging it back in. Make sure that it isn't your cable box by looking at the T.V. menu and seeing if there's red in the menus or by using a DVD player connected to the TV. Try switching the inputs to see if just one input is stealing the red, otherwise you have a bad main board. Generally a 240-275 about fix.
Jun 07, 2011 | Sharp LC-26DV12U 26 in. LCD TV/DVD Combo
Ok i have a 47in samsung hd tv today it started acting funny the picture and colors arent right like there a blue red and green colors its like the main picture is being copied 3x times once by each color...
this issue is caused by a failure in the convergence ic's and possibly a bad resistor and fuse in the circuit if you need instrution on how to change I may be able to help though it is kinda tech heavy
Jan 25, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I have a 60" projection tv philips magnavox model #9P6040 C104 PTV843. The color looks bad, the picture looks orange and red. What do I need to fix it and how much will it be.
You have one of two problems based on your description.
1.) Go to a channel that is in black and white and turn the color on the set all the way off.
Examine the screen and picture from several feet back----if the picture is mostly red and looks somewhat yellow in the main part of the screen you have a GLYCOL problem.
These sets have on each picture tube a sealed unit full of Glycol to cool the face of each tube (set has a red, green, blue picture tube)
If you find the yellow/orange look with the color off you most likely have bad Glycol in the blue picture tube---it never happens to the red--bacteria gets into the glycol and eventually there is no picture coming from (in most cases) the blue tube.
Loss of blue will leave you with Red and Green--mix those two and you usually get a orange/red affect.
There is a way to also confirm this with your eyes--it involves getting the back cover off of the set and holding a small mirror (with the set turned on--you have to be careful not to touch anything)
If you look in each lens you should see a fine picture--one red, one green and one blue--if as I suspect the blue tube is contaminated it will not have a picture and will look like a blue floodlight.
IF THIS IS NOT YOUR PROBLEM--GO into the customer menu and select convergence--what you are looking for is will red and blue adjust or not--are they skewed and will not move.
If this is the case you have a convergence problem--I can tell you what is involved to fix in either case.
Let me know what you find--I am here to help people.
If this information has helped you, rate this solution as I do this here for free.
SD TECH
Nov 08, 2009 | Philips Magnavox 9P6034C 60" Rear...
The dark color of my tv was change unspected the dark color now are blue, violet,and other exept black, the dark scense can't see. please help me.
I believe you either have a bad LCD Controller Board or a bad Main Board. The only way to know is to replace one. If it doesn't fix it , replace the other. Or replace both and it should be fixed.
I hope this helps,
Skyassoc
Nov 03, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
Color picture jumps in and out of normal color mode . . .
You have bad solder connection in or around the Jungle IC and or color processing Circuits. Most commonly the area is the color cyrstal, located on the main board.
Oct 10, 2009 | Televison & Video
The picture comes in good except that the colors red,pink and blue has become real dominant I tried to adjust the color but those 3 colors reall show through
Hitachi was know for their problems with picture tub sets. Every time is was the main the board was bad that was control green gun.
Aug 12, 2009 | Hitachi Televison & Video
Dell 2300mp projector, colors bad
try reseating the vga cable. Try removing the cable, the green tint should disappear meaning that the color or lack of one of the primary colors blue/red/green were missing due to bad connection. or maybe you have a bad vga cable.
Feb 26, 2009 | Dell 2300MP Multimedia Projector
Green/Blue distorted Colors
Color issues are harder to solve without seeing the problem. It sound like the red amplifier on the crt board is bad. Is there any red in the picture at all? If not, that will be you problem
Nov 26, 2008 | Televison & Video
Bad Color - Not much red
picture tube is goin bad............
Dec 28, 2007 | Sony KV-32S26 32" TV
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
