Question about Kenmore 57029 Side by Side Refrigerator
Kenmore side by side refrigerator
Water dispenser is loose and won't work properly, how can I tighten it up without completely breaking it? Please help!
Thank You
  • 1 more comment
  • Phyllis Jennings May 09, 2009
    Thank You Vic I'll try to do and see if that helps.
    Hi mnichols0205,
    the paddle is very loose and it's tricky trying to dispense water but once you jiggle it around for a while it dispense's unexpectantly.
  • Mark Nichols May 11, 2010
    the paddle is loose?
    President:
  • 1,136 Answers
If you are asking about the dispenser lever, There is a good chance it is already broke. You will need to remove the front cover. On most models, you will need a standard flat blade screwdriver and then locate the indentations on the underside of the cover trim. It takes a little force to pop the cover trim away from the door, but it will come loose. Once you have removed the cover, the dispesnser levers should be visible.
I hope this will help you to at least determine weather you can just tighten it or need to replace the lever. Please let me know if I have helped you. I can also look up the correct part and get it shipped to you.
Hope I helped
Vic
Posted on May 08, 2009
Why won't the water dispenser work in my kenmore
What is the complete model number of your unit?
Look for the number in the refrigerator section.
Apr 06, 2013 | Refrigerators
Why doesnt the water and ice work on my side x side kenmore refridgerator
1st-Make sure you have water entering the unit. 2nd- If you have recently replaced the water filter- make sure it is properly installed. When you press the water dispenser, you should be able to hear the water valve energizing. If all fails, your best resource is to have a Sears tech service the unit specially if Ice-maker continues Not to function. It might be costly but they warranty the work without any stories.
Oct 05, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore Elite Refrigerator water dispenser mechanism will not turn off. I turned off the water from the valve under my sink that is connected to the water line, however, I can hear the dispenser still...
most panels have 2 screws under the edge . remoce them and the panel will come off . there must be a bad sw or something caught in sw .. sw do go bad .. mm hope this helped feed back pls .
Feb 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore side-by-side refrigerator and the water dipenser quit working, the ice maker works fine. Any solutions?
Check water valves on back of fridge, one is for the ice maker and other is for water dispenser. Need to get the correct and complete model number listed on front and near floor behind the fresh food door. Problem may be the water valve in back or the dispenser switch on the front. let me know and I will try to get it going for you.
Thanks, Sea Breeze
Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Not dispensing water
more likely the switch braket has broken. this unit has a bracket that holds the micro switches on small plastic pins and they break easily. you didnt list a model number but you an secure the part thru partsdirect.com and here are the steps for repairing the unit:
  • first unplug unit
  • remove disp cover, look on bottom edge of the cover and you will see 2 slots for a flat tip srew driver carefully pry the cover off
  • you will expose the switch bracket and most likely will see the broken pins.
  • just change the switches and light socket over to the new bracket (dont forget to install the switch spacers)
some models have 2 screws under the drip tray as opposed to having to pry the cover off.
If this doesnt sound like your refrig post a complete model number and I will get you the proper instructions. thanks peyton
Mar 16, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
New filter but water dispenser still not working
Check the water valve if its working most probably watewr line inbetween the water valve and the water dispencer is frozen. Un plug the refrigarator for four hours and try again.
Mar 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
After using the water dispenser on my side by side ED20DF the water keeps on dripping? I've turned the water off for now, but I need to know how to fix it. Help??? Thanks
Could be couple of thing, but I think that first you need to check the connector. You open your refrigerator from both sides and then pull out the grille (don't worry it won't break) then if you see at your left there's a connector that put together a 5/16 water tube with a 1/4 water tube, try to fit both water tubes in the connector, maybe one of those is loose and that's the why of the dripping.
The other thing may be is with the mechanical-electrical interface, when you press the paddle, is you see the activation under the dispenser, it touches with a limit switch, maybe the limit switch is stuck with something when you activate or it is not working properly.
Also if you have a multimeter check the valve to see if it's not a problem with the signal that is coming to the valve, I mean if the problem is that even without press the paddle the dispenser start to dispense water.
Feb 19, 2009 | Whirlpool GS6NBEXR Side by Side...
Kenmore - Side by Side condensation in water/ice dispensor area
maker sure your flapper is closing all the way the trim plate will come off its snapped on once you get it strated it will come they are a bear use butter knife to pop it loose on cornor first hope this helps
Sep 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
Water dispenser not working
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Mar 10, 2007 | GE GSH25JFR Side by Side Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
