Question about Bose Lifestyle Ps28 Iii Subwoofer Dual Voltage 110-240 V For V20 T20 V25 28 Iii
Lite on sub woofer don't lite up and system is not working.
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Hi I have the Acoustimass 15 series 2 system, my
Acoustimass 15 series 2 system is available in Amazon.com
Click above link to view price info.
However, you can use Acoustimass 10 series 3 system too as both has same output that is 200W and it is also available in Amazon.com
Hope these info will help you.
Thanks.
Posted on Sep 24, 2010
Interior lite and doorajar lite don't work when passenger door is not closed
a faulty wire on door check your fuses and replace them for the doors
Jan 14, 2013 | Cars & Trucks
How can I do a system update on my nintendo ds lite.
Becareful R4s are now illegal in the uk so bit dodgey asking
Nov 15, 2011 | Nintendo DS Lite Console
Hi i purchased the bnps102 woofers and used them for 2 weeks i really enjoyed them and i also purchased the pyle 1400 watt amp and a jvc deck along with the boss amp kit installation now the speakers about...
If the lights on your sub box aren't coming on it's either your ground of power wire came loose or the transformer blew. As for the subs, make sure all the connections are good, especially on your RCA wires. If your amp is getting power, then check your speaker connections. Also, make sure to turn the gain know up. The gain knob is located next to the RCA input on the amp. Let me know if this helps.
Aug 21, 2011 | Pyramid BNPS102 Car Subwoofer
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
We have a Harman Kardon home theatre system that is between 5-10 years old. The subwoofer has SUB-TS5 on the back and is currently not working. We noticed in the past when watching an action movie that...
The sub-ts5 had glue that went conductive on the circuit board and when it is removed unit should work again a good tech should be able to fix this for you
Feb 04, 2011 | Harman Kardon Audio Players & Recorders
I hook up my brake lite switch to rear lites and
you need to update the wiring on the rear on place diodes in the circuir to keep them from backfeeding.
Apr 06, 2010 | 1983 Dodge Challenger
Won't work after re-installing Boston speakers
would try it with the correctly rated fuse as there may not be enough wattage / current to power the bass unit with a thin wire.
Also how long ago was it flooded as it may take quite a while in a warm area to dry off completely ?
Apr 11, 2009 | Boston Acoustics BA735 Computer Speakers
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
The subwoofer lites but no sound
Have you gone into the menu settings and adjusted the sub woofer volume, some factory settings are set @ zero.
Sep 09, 2008 | JVC TH-M55 System
Sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
May 15, 2008 | Audio Players & Recorders
Bose Lifestyle Ps28 Iii Subwoofer Dual Voltage 110-240 V For V20 T20 V25 28 Iii Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
