Question about Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum
8231900 switch switch for qpl60 shopvac
Mod.#J150A shopvac won't turn on
These units are not high quality. There are problems with the motors and the switches, you can check these things or just get another one. If you get another one, get a different brand.
Feb 09, 2014 | Vacuums
Is the shopvac qsp 10 for water
yes it is wet and dry cac go to link below for deiails
http://www.shopvac.com/pdf/Shop-Vac-QSP.pdf
Nov 08, 2012 | Vacuums
Vacuum shut off and will not turn on again. What could be wrong?.
Your switch died, it happens a lot with this brand of shopvac. Just extract the little switch behind the big rocker switch and replace it with one from radio shack, or replace it with a toggle switch. Cheap and easy to do.
Mar 15, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Shopvac 90L400 quit working (4 years old). Thought the switch was bad but not the problem. I read that there is a fuse link in the motor that frequently burns up. I tried to take motor apart but not sure...
by pass the switch and take power right to the motor leads.. that should tell you if the motor is ok.. have not seen fuse link on a vac motor.. graingers has new motors, but not inexpensive
Nov 30, 2009 | Vacuums
I have a shopvac model#86776-24. The toggle switch went bad and I'm looking for a replacement switch
I got a replacement switch at a local electronic supply store: Philmore Miniature Rocker Switch part number 30-043. Shop vac changed the switch recently to two push buttons from the old rocker style. This update works a lot better.
Oct 25, 2009 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Need switch for a shop vac modle qpl650
Ok - heres my story - QPL650 crapped out mid job, checked this post, ordered the switch on the link here, didn't work.
Called Shop Vac, priced a power unit assembley ($82), took the motor apart and traced the orange wires into small junction box, replaced the little rod connecting the contacts with a 1/2" of coat hanger (white paint scaped off first) and I am back in business.
Now I am thinking $82 invested in an index fund at 6% per annum for 20 years is...................
Dec 12, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Shop vac QPL625 on off switch stays on.
Contact Digi-Key 1-800-344-4539 or 218-681-6674 ask for part number EG1505-ND.
Cost is about $2.00 plus shipping.
See http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=EG1505-ND for part details.
You want a D.P.S.T (On/Off) mini-rocker switch.
Apr 16, 2008 | Vacuums
Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum Logo
21 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
 John
John
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
