Question about Plantronics 510 Voyager Headset - PLN-510 Headset
Turning the plantronics 510 headset off
Can not remember how to turn the headset (plantronics 510) on and off, more specifically off
  • marion_king May 08, 2009
    anyone know how to turn the plantronics 510 headset off, i have tried just about all of the buttons and do not have a owners manual
  • 3 Answers
Holding down the small black button at the top of the earpiece will power down the headset. Plantronics offers great support too so you can contact them at plantronics.com or check out the Plantronics 510 manual for info.
Posted on Jun 01, 2009
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Good luck from Headsets Direct!
Oct 19, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Tip
How to Pair or Connect the Plantronics 510 Bluetooth Headset to your Bluetooth...
1. Turn on Bluetooth within your phone - Consult phone instruction booklet
2. Put phone into pairing mode - Consult phone instruction booklet
3. Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
4. Select "Add new device" on your phone.
5. Select the Plantronics headset when prompted. Enter "0000" as passcode.
6. Your 510 headset will now have a continuous blue light blinking.
7. Choose "Yes" if your phones asks if you want to bond to the 510 bluetooth headset.
8. Your phone is now paired with the Plantronics 510 headset and ready for use.
on Jul 14, 2010 | Cell Phones
My headset will not hold the charge very long - is there a fix for this - is there a battery somewhere on this unit that can be replaced?
Unfortunately, the Plantronics Voyager 510 Bluetooth headset does not have a replaceable battery, it is "hard wired". However the 510 headset does have a one year warranty, so Plantronics will replace it within the warranty period. If it's out of warranty, you can buy a replacement if you'd like or buy the newer version which is the Plantronics Voyager Pro+, which is just a newer, slimmer model and it also has newer technology (for the same cost). Here are the links below.
Here is the link to the Plantronics 510 replacement headset.
Here is the link to the Plantronics Voyager Pro+.
Aug 25, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Can't hear my pc to head set..can u help
Hearing a Plantronics Voyager 510 headset through a computer:
To use a Plantronics Voyager 510 headset through your computer, you either need a USB Bluetooth adapter or you must have Bluetooth built in to your computer. Once the Voyager 510 headset is "connected" to your pc (by one of the mentioned ways), you may need to go into the control panel on the computer or the specific software program being used to set the Plantronics Voyager 510 headset as the "default device". Keep in mind that the headset has to be powered on and to also have to activate the headset to connect to the Bluetooth adapter or computer.
Good luck from Headsets Direct - 800-914-7996.
Aug 20, 2011 | Plantronics 510 Voyager Headset - PLN-510...
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Aug 13, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do I put the unit in discover mode
Putting the Plantronics Voyager 510 into pairing mode:
With headset on, press and hold the call button and the volume up simultaneously until the headset begins to flash red and blue.
Select the Plantronics 510 headset in your phone when prompted and enter 0000 (4 zeros) as the PIN/passcode if prompted. When paired, the Voyager 510 headset should now have a continuous blinking blue light. Here is a link below for the step by step pairing instructions.
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
Aug 12, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do i conect to my phone
Connecting or Pairing your Plantronics Voyager 510 Bluetooth Headset will take less than a minute. Click on the following link for instructions with photo so you know which buttons to press:
Pair Plantronics 510 Headset
Good Luck from Headsets Direct!
Apr 23, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Blue tooth pass code
Typical pairing code for PLT Voyager 510 is 0000
Dec 19, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Pairing headset with phone
You can download manuals from this link: http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8079&p_created=1125099403&p_sid=BnXTqpIi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzMmcF9wcm9kcz02MiwxNjYmcF9jYXRzPSZwX3B2PTIuMTY2JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1 There is an online pairing guide below: http://www.plantronics.com/media/media_resources/easytopair/index.html?WT.mc_t=EasyToPair&WT.mc_n=EasyToPair&WT.srch=1
Aug 05, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
1,752 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
