Question about Samsung BN59-00678A Remote Control
I can't opoen
I have problems for changing channels and my friend says that need open for clean inside.
I lost my remote and can't change the channel on the control panel. It is on channel 02 and it won't change even when I hit the channel+ or channel- button.
Hello.
Your problem is stuck keys in your T.V. It usually just needs cleaning, BUT it is hard to clean, because you gonna have to open up the whole TV. I advice you just buy a new remote from JVC or just buy a "Universal Remote".
Jul 18, 2011 | JVC AV-32D305 32" TV
I have a galaxy 2547 and it is stuck on freq 27.850 is there a controler board or something that good have shorted out?
There is a board inside that Galaxy radio called a PCB board. When they go bad they freeze on the frequency they are on. Replace that board and this should take care of the problem. I trust Maycomm Communications for all my Galaxy repair parts needs. http://maycomcomm.com/
Mar 10, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
We have a wind column wind chaser fan and the screws look like they require a special wrench to open and clean it. Model wcft62 Is there anyway to get iot opoen to clean it without the special screw...
Harbor Freight stores have a 'security bit' kit for about $10 that will turn about any screw fastener made. If you have no local store, look for them on-line. Hope this helps!
Nov 11, 2010 | Windchaser WCUFI WindColumnUltra Tower Fan
Says back cover is open when door is closed.
Hello. Unplug the printer. Leave it unplugged for two full minutes. Plug it in, opoen the back cover and forcefully shut it.
This should solve your problem. J.
Aug 17, 2010 | Brother DCP-7020 Black and White Copier
My sony remote control does not change the channels using channel change button
looks like you change channels too much, with the result the inside rubber contacts have eroded. if you know how to open it and clean the channel contact with alcohol and put everything back together. most remotes have screws in the battery compartment, but you have to pry open CAREFULLY but pressing side cover joints for hook to be pushed in with gentle pressure. you may have to use two flat screw drivers to pry open side. This may or may not work depending on what and how you do it. Experts can do it.sometimes i have to put silver foil inside to make it work. GL
Apr 08, 2010 | Televison & Video
How to repair my bluetooth on my nokia 6600
If you can't opoen gallery too,Usually its a hardware problem.so to fix the problem are changing bluetooth module itself.or you can reheat first in some case its works.But if you still can open gallery its mean a software problem. Good luck.
Mar 04, 2010 | Nokia 6600
When I adjust the volume on the remote control it changes the channel, but not on every occasion.
Hey,
This could be due to the accumulation of dust inside the remote control. You can try to open up the controller and just clean it up.
Thanks
Apr 15, 2009 | Televison & Video
PROTECTION LIGHT IS FLASHING
opoen it up again and look at the mosfets leads use a needle nose pliers to make sure that non fried off that is a common problem
Apr 02, 2009 | Alpine MRV-1507 Car Audio Amplifier
Dryer gas valve
the valve should be closed until the coils on the top are energized and opoen the valve check the incomming connection for leaks all gas valve fail safe that is to say they wont fail to the open position.. use some dish soap and water on the piping into the unit and around the valve to find the leak
Mar 15, 2008 | Dryers
Dishwasher tablet not releasing
sounds like the dispenser solenoid is faulty you will need to replace the whole unit, this involves removing the door panel.
Jun 08, 2007 | Indesit 24 in. DE73 Evolution...
Samsung BN59-00678A Remote Control Logo
Henry  Thomas
Henry Thomas
