Question about RCA TruFlat 27F520T 27" TV
Can only see half the picture
We've had our tv for about 2 years now and all the sudden it is showing only the bottom half of the picture... the top half is black and there is a thick line going across the middle like it has shrunk the whole top half down into that line.  We've tried switching channels and unplugging the TV and back in - get the same results every time.  The picture at the bottom of the screen is clear and the sound is fine.
  • 1 more comment
  • butterfly888 Nov 05, 2007
    SANSUI CTV-2911PF
    29 INCH/68CM pure flat AV stereo tv
    picture appears across the middle of the screen all squashed up
    tv is only 2 years old but out of warranty
  • jimb67 Nov 08, 2007
    50 inch toshiba projection tv ---three years old--can only see bottom half--burning color strips across centerline
  • valowee Nov 10, 2007
    We too, after having the tv for 2 years, are only getting half of the picture (bottom half) and the top is shrunk down to the middle line. Very annoying to watch (obviously). Picture at bottom is clear and sound is fine. Do I try to fix myself and if so how exactly? Where is the vertical output device? Where do I buy an OEM equiv. or better like one solution says?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Your problem is in vertical output section.
the ckt which is connected to vertical output section is called feedback ckt.
please check.
1 loose contact in feed back ckt.
2 mostly this problem is due to electrolytic capacitor failure.
3 vertical output  IC or transistor failure.
4 check for proper supply to vertical output.
5  low value resistor failure in v/output ckt  (.in rare case)
IF YOU ARE NOT TECH PERSON PLEASE TAKE HELP.
  1. hope this will help.
Posted on Oct 10, 2007
    Genius:
  • 1,694 Answers
Locate Vertical Output device--replace w/OEM equiv.or better.
There are vertical 1" to 2" black lines that come and go. They are on the top half of the screen only. Also, the TV takes 40 min of flashing before the picture comes on. Our TV is about 5 years old. ...
Yes,This tv have two problems.One is the power supply board have dead capacitors,need it to replaced,the other is the vertical lining board on the bottom near the speakers need all the old lining to resolders.The shop will cost u $ half to repair,it to buy a new tv.
Apr 04, 2010 | Toshiba 42HP84 42 in. Plasma HDTV
The lower half of the tv goes black/also pastel colors
yes humidity has been known to make the panel seperate. I live in south tx and work for sony, alot of panels that show that prob is usually the panel seperating. wouldnt recomend to fix to costly around 85% the cost of when you bought it.
Jul 03, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Old tv only shows half picture
it looks like some caps are bad in the set.
Have it serviced by a TV repair shop
Aug 02, 2008 | Televison & Video
Sanyo dp42746 half screen blacking out
http://cgi.ebay.com/philips-plasma-Y-board_W0QQitemZ270262136649QQcmdZViewItem?hash=item270262136649&_trkparms=72%3A552%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1318
Jul 20, 2008 | Sanyo DP42746 42 in. Plasma Television
1/2 the picture
Hello
You will have to a tec. for this one as you have lost half of your vertical sweep.
Sorry
guy9
Jun 16, 2008 | LG 42PX5D 42 in. Plasma HDTV
Samsung HP-R4252 42 in. HDTV screen black outs and red lines
Hi: We had this problem under warranty, and tech installed the following to solve it: Parts BN96-02033A, BN96-02034A and BN96-02216A. This solved the problem for 2 years. I now have the upper half going black now and then for 2 to 3 seconds. I am ordering these parts from www.partstore.com and will just plug them in. Better than a new tv.
May 25, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
Sony Trinitron Top Half picture blacked out
You could have a bad capacitor 35v 100uf ,1uf 50v ,VERTICAL ICs have 7-11pins depends on which one you need LA7830-or 7833,7835,7836,7837 7838 make sure you get correct part.
ThankYou for using FixYa. Have a Nice Day
Feb 07, 2008 | Samsung HCM4216W 42" Rear Projection...
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
RCA TruFlat  27F520T 27" TV Logo
417 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
