Question about Vulcan Ovens
Piazzo igniter - Vulcan Ovens
Oven starts and stops
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 02, 2014 | Kenmore Ovens
Kirkland sgs375hq
Mar 20, 2014 | Whirlpool Ovens
If oven igniter is not getting power what is the cause. Oven is plugged in. Broiler igniter works.
Feb 04, 2014 | Kenmore Ovens
I have kenmore gas oven ignitor glows but will not light
Hello there:
It doesn't bake dot_lineone.gif Bake igniter
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
If you are certain the igniter is ok, it might be a good idea to call a professional appliance technician.
Need a new oven igniter? Click here for most common oven igniters or enter your oven model number in our PART SEARCH. ^ top clear.gif It doesn't broil dot_lineone.gif Broil igniter
When the broil igniter becomes weak or burns out, your oven would not broil. The broil igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the broil igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#ixzz1CgFQ7lBJ
Feb 01, 2011 | Kenmore 33169 Gas Single Oven
Oven does not light igniter glows but no flame
This happens when an oven igniter (glow bar) is bad. The igniter must draw enough amps to turn on the gas to ignite the flame. If you have a square shaped igniter use this part#5303935066 If your have a round shaped igniter use part#wb2x9154. These igniter will pretty much work universally for most gas ranges or ovens.
  1. Remove the racks
  2. Unplug unit
  3. Take out the screw holding the bottom pan
  4. Remove screws holding manifold where igniter is attached
  5. Remove manifold cut wires about 2in link from igniter and clean leads.
  6. Unscrew and remove igniter
  7. Replace Igniter with new one and fasten onto manifold
  8. Clean wires and screw on ceramic nuts to wires
  9. Tuck wires back and Reinstall all components
Test your new igniter. You might notice it taking a little longer to light up but that is okay.
Please let me know if this was helpful by rating me a 4.
Thanks so much have a great weekend.
Dec 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Replace igniter part # 1990 in oven of model #3627332192
It's usually pretty simple. Start by turning power off to the oven - unplug it or disconnect power at the circuit breaker. Open oven door, remove all racks, then remove oven floor panel (it might be secured with two bolts or clips on the back side). Remove the flame spreader (one nut). Now you have the oven burner and igniter exposed. If the new plug differs from the old, cut off the plug and use ceramic wire nuts (should be supplied with igniter) to connect the wires. Don't shake the igniter - the coil is very fragile. Once the igniter is replaced make sure the wires are connected securely. Put everything back the way it was and test the oven.
Below are the two most popular oven igniters: flat bar igniter and round igniter.
Flat igniter - this is by far the most commonly used oven igniter. Includes all necessary pieces to replace longer ceramics. Size: 3-3/4" long. Fits Maytag, Whirlpool, KitchenAid, Magic Chef, Tappan, Jenn Air, GE (flat bar only), Sears Kenmore (flat bar only), even some Thermador cooktops and Viking ovens. - ff693fe.jpeg
Feb 25, 2010 | Kenmore Ovens
Igniters will not stop clicking.
Hi
Thanks for using FIxYa.The igniter doesn't stop clicking due to a short inside the igniter circuit or due to moisture present on the ignition switch.Turn off the gas supply immediately and also unplug it from the mains power. Now take a blower or your hair dryer and blow hot air over the igniter. Also check for the following troubleshooting steps---
1) The gap between the igniter and the burner base is too large. *Should be approximately the thickness of two dimes.
2) Soiled igniter or burner base.
The above can be tested by switching the suspected burner with a known operating burner.
3) Loose wiring connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched igniter wire between the burner and module.
Both of the above are physical inspections under the main top.
5) The module may have a week coil, which is not providing sufficient voltage to ignite the gas.
Even after performing these steps the igniter doesn't stop clicking then you need to replace the spark module.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
Oven won't ignite but broiler does
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Aug 11, 2009 | Ovens
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Stoves 900GRa spark ignition
i have a 900g stoves oven how do you change from auto to manual
Nov 02, 2008 | Stoves Premier 900GRa Gas Double Oven
Ovens Logo
19 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Treefrog15
Treefrog15
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
