Question about Dryers
HAS POWER THE TIMER IS CLICKING BUT THE DRYER IS NOT ON MAYTAG PERFORMA
  • 10 more comments
  • garymjr May 08, 2009
    not sure if its the swich or the door safety or somethign totaly diferent but can you test the door safety with a jumper wire ? and can you test the switch?
    im not sure were the other on is theres on behind the door and there is a relay in the housing behind the on off switch is that the other one and can you jump them with power on or will it short out and how do you test the switch it has lile 15 wires all different colors?
    i can not hear the motor
    model # pyet244ayw
    thank you
    thanks  i checked with the power off there is continuity in the door safety switch and none in the thermal safety switch what does that mean???is it still the problem
    there is one cicle under ther element but outside the element houseing about the size of a quater and has 2 electrical conecters to it i tested it and it has no continuity is there another i dont see it is it somewere else and thanks so much for your help.
  • Victor
    Victor May 11, 2010
    Hi, It sounds like your thermal safty stat has went bad. If you could send me model #, I can look up your model and give you an answer to locate the safty so you can test it.
    Vic
  • Samuel Charles Spriggs May 11, 2010
    Looks like you have plenty of help --- have a good evening.
  • Mark Nichols May 11, 2010
    Yes hook the two wires together on both things try one first if that works change it if not put it back on and then check the other
    check the safety by the heating element, or i wonder if the door switch is broke
    Can you hear the motor turning -- it will be very faint.
    President:
  • 1,136 Answers
Thanks or the #. Ok, The safty is located next to the heating element. To get to the safety, You need to pop the top of the dryer be inserting a flat blade screwdriver into the gap between the dryer front panel and the dryer top and push down on the screwdriver to seperate to two panels. Once you have done this, the element can be located at the rear top edge of the drum. A 1/4" screw will hold the safety stat and one holding the element. after you have removed the element from it's housing (Be carefully when lifting the element out so that you DO NOT break any of the ceramic holding the element. Now you will find the safety fuse on the right side of the element housing. Notice as you remove the safety how it mounts to the housing. Check continuity on the safety fuse. If you find the fuse is open, it will need to be replaced.
I can send you the proper kit if you would like.
Hope this helps.
Vic
Posted on May 08, 2009
Testimonial: "THANK YOU VERY HELPFULL "
  • Victor
    Victor May 08, 2009
    If you have no continuity in the safety, it is bad and needs replaced. Are you talking about the safety on the right side of the housing (Smallest of the two stats)?
  • Victor
    Victor May 08, 2009
    I would just like to know if I helped you at all.
Maytag Performa will not turn on. (4 Years old) There is power to it. You can hear a fainting clicking of the timer when you dial a setting
Have you tried moving the selection switch a hair at a time while in the ON position? The timer may be corroded -- if you can get to it it is easy to see the points and clean them with sandpaper or file. If so, the timer is moving but is not making a connection due to crud.
Dec 04, 2010 | Dryers
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
Maytag Performa Electric dryer timer is bad
Look up an appliance parts store in your area. If there is no appliance store, try www.searspartsdirect.com.
If it does not turn off during timed dry then it for sure has gone bad. If it takes a while on timed dry then it is most likely that your thermal fuse/ valve coils are going bad.
Jan 14, 2010 | Dryers
Maytag Performa Dryer won't start.
I would suggest checking and probly replacing especially if you cant hear the timer motor.
Mar 28, 2009 | Zanussi TD4112W Electric Dryer
Maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Jan 26, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa gas dryer no longer produces heat.
needs a new timer switch sometimes cheaper to buy another dryer (used)
Dec 02, 2008 | Maytag Performa PAV2200
Performa Dryer
which machine, what brand, what washer, or what dryer????????????
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jul 20, 2008 | Maytag Performa PAV2200
Dryers Logo
204 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
