Question about Sony STR-DE845 Receiver
Need to cancel vol min
Sound is set to vol min
How do set the wake up alarm on am/fm digital clock radio model ONB14AV201
1. With the unit in CLOCK mode, press and hold the ALM1/VOL+ or ALM2/VOL? button. The ALARM time will begin to flash on the LED display.
2. Press the ?/HR button to adjust the alarm hour.
3. Press the ?/MIN button to adjust the alarm minute.
4. When the correct time is selected, press the ALM1/VOL+ or ALM2/VOL? button to confirm.
5. Press the ALM1/VOL+ or ALM2/VOL? button to select the ALARM sound mode - buzzer or currently set radio station. The alarm buzzer or radio indicator will light up.
Jan 21, 2015 | Audio Players & Recorders
Very odd problem
It is a fault with the control board or with panel.
Aug 24, 2008 | Philips 43P8341 43" Rear Projection...
Unmute handset
Mute Microphone
With the handset
You can temporarily turn Off the microphone so that the person you are talking with cannot hear you.
1)Press menu/del during talk mode (while phone is in use).
2)Press ring/vol/? or ring/vol/? to move the pointer to Mute and then select/
Mute On and appear in the display. To cancel muting, repeat above step again when Mute
is set to on, Mute Off appears.
With the base
While using the base speakerphone, press mute on the base to turn Off the microphone.
Press mute again or press (speaker) to cancel muting.
Jan 01, 2015 | Uniden Lands Phones
How can I adjust the screen so I can see the score of the football game it is cut off on my Panasonic TH-50PX75U
Hello
To do this you have to enter into the service mode, ie, factory setting modes, which oly will allow you to do the screen adjustments. Your TV needs vertical S-Correction, to avoid lower side stretch. Four methods to enter into the service mode are given here . Just try OK.
In Sound-Menu Low-tone-regel to MAX and
High-tone-regel to MIN. Press 'F' button on TV.
Then press VOL- on TV and REVEAL on RC in
some time. Select: red and green buttons.
Adjust: yellow and blue buttons. Store:
'STR'. Exit: 'N' on RC.
High-tone-regel to MIN. Press VOL- on TV
and RESET on RC in some time. Select: red
and green buttons. Adjust: yellow and blue
buttons. Store: 'STORE'. Exit: switch off.
ON: Press simultaneously 'OFF TIMER' on RC
and 'CH.UP' local.
OFF: Press simultaneously 'OFF TIMER' on RC
and 'VOL-' local.
Simultaneously press 'RECALL' on RC and
'VOL-' local. Exit: 'NORMAL' on RC.
After entering into this mode, be careful not to spoil the set. Mark all the initial values on a paper for refernce, and begin to chage the values. You may only have to chage the value of "SC".
Nov 22, 2010 | Samsung TXJ3678 36" TV
My television is locked on parental control and I do not have the code, how do I unlock it? Model # F19431
Simultaneously press and hold VOL- on the television and VOL- on the remote for 3 seconds. (Nothing appears on the screen - Parental controls simply unlock.) You can re-enter a password via Lock Parental Controls, if you wish.
Apr 12, 2009 | RCA F19431 19" TV
Forgot codes of SHG-D500 cell phone - sound settings
I was suprised to see quite a few people are tweaking their sound settings and various other things -
thanks very much for the insightful help offered for my queries.
It might be an abuse of space, but If anyone else happens to needs/wants the defaults values SHG D500 Samsung Test Mode they are:.
Code: *#8999*8378# ( * means press star)
Normal
MIC gain - 0
Tx PGA - 70
Side PGA - 0
Ear gain - 3
HFR gain - 9
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv3 - 11
Rx comp - Lv 4 - 29
Rx comp - Lv 5 - 30
Key vol - Lv1 - 64
Key vol - Lv2 - 64
Key vol - Lv3 - 64
Key vol - Lv4 - 64
Key vol - Lv5 - 64
Headset
MIC gain - 0
Tx PGA - 64
Side PGA - 0
Ear gain - 13
HFR gain - 3
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 20
Rx vol - Lv 3 - 42
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 146
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv 3 - 11
Rx comp - Lv 4 - 30
Rx comp - Lv 5 - 28
Key vol - Lv1 - 10
Key vol - Lv2 - 20
Key vol - Lv3 - 42
Key vol - Lv4 - 76
Key vol - Lv5 146
Loud SPK SUP
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK SDN
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK EXT
MIC gain - 1
Tx PGA - 226
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 92
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 5
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK Out Only
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Yamaha AMP vol.
31
Yamaha MEL vol.
Normal
Lv 1 - 6
Lv 2 - 12
Lv 3 - 18
Lv 4 - 24
Lv 5 - 31
Melody key
Lv 1 - 2
Lv 2 - 4
Lv 3 - 11
Lv 4 - 18
Lv 5 - 25
Power on/off
Lv 1 - 1
Lv 2 - 10
Lv 3 - 14
Lv 4 - 18
Lv 5 - 22
ISS Normal
Ear gain - 12
HFR gain - 3
Rx vol - Lv 1 - 121
Rx vol - Lv 2 - 186
Rx vol - Lv 3 - 268
Rx vol - Lv 4 - 376
Rx vol - Lv 5 - 564
Rx vol - Lv 6 - 802
Rx vol - Lv 7 - 980
Rx vol - Lv 8 - 1560
Rx vol - Lv 9 - 2167
Rx vol - Lv 10 - 2863
ISS Headset
Ear gain - 10
HFR gain - 3
Rx vol - Lv 1 - 164
Rx vol - Lv 2 - 328
Rx vol - Lv 3 - 492
Rx vol - Lv 4 - 656
Rx vol - Lv 5 - 820
Rx vol - Lv 6 - 984
Rx vol - Lv 7 - 1148
Rx vol - Lv 8 - 1312
Rx vol - Lv 9 - 1476
Rx vol - Lv 10 - 1640
Bluetooth
Tx PGA - 255
Rx PGA - 12
Side PGA - 0
Mar 19, 2009 | Samsung Cell Phones
N73: difficault to open message ,dont ring when called,vol adj.
restore your factory setting or hard format your fone,,, to hard format, pres and hold *3 and the send key for 2 mins and ask someone to help switch it on while you still hold the three keys together,,thanks
Dec 30, 2008 | Nokia N73 Cellular Phone
Panasonic tv
- push menu
-setup
-ant cable
-sleep 30 min
-ch 124
-vol min with remote
-press vol - in front tv
- aparece chk you see
-with button poweer select
- push pwr & action to exit
jesustolu_9244@hotmail.com
Sep 12, 2008 | Panasonic CT-27SL15 27" TV
Code
PIN CODE RESET - UNPLUG SET FOR 2HOURS, VOL TO MIN. PRESS VOL- ON SET & "7" ON R/C FOR 5 SECS WHEN "PROTECTED"
Jan 05, 2008 | Aiwa VX-T1470 14 in. TV/VCR Combo
Sony STR-DE845 Receiver Logo
16 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
