Question about Ruud Heating & Cooling
Carrier weathermaker cd5axa036
I have this unit and the furnace will not work. Cooling system works fine but furnace will not operate. The circuit board has been replaced two yeas ago and now seems to have failed again. The red LED is blinking and service tech says this is due to short in the board. He has priced the board at $300.00. Does this sound accurate? Is this board available for a better price?
SOURCE: Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Posted on Dec 20, 2008
pierre1811
  • 144 Answers
SOURCE: Carrier Weathermaker SX (model 58SX100)
There is a small tube that comes off the inducer for cracks or water. If there are cracks then the pressure switch that it is attached to may not be closing all of the time. Also sometimes you can get water in that tubing which will also cause the pressure switch to not close. If thats the case shorten the tube so there is no low droop in it where water can collect. Another thing that I would do is disconnect the tube at the indicer, take a straightened out paper clip or stiff wire and poke it in the nipple on the inducer to make sure it is clear too. Let me know if any of these work. There may be other things we can do.
Posted on Jan 19, 2009
farfield
  • 462 Answers
SOURCE: Carrier Weathermaker SXI Model 58SX8100LG Code 12
Code 12 I believe is power up after power off and a call for heat from the the thermostat. If you have a weak door switch that may be vibrating and going on and off it would cause this as would any thing that causes the power to drop low or out then reapply its self. try holding the door switch in while watching the board and after 2 or 3 minutes the furnace should go on to lite and the blower cycle off. If it stays in this mode try turning the thermostat off (heat - OFF -cool) and then push in the door switch nothing should happen except the lite on the board come on and stay on. If it does this than have someone turn the thermostat to heat and see if it starts or put the door on and set the heat and see if *** goes through the normal cycle of heating. If however it goes right back into the blower mode and shows the 12 code your problem is still with you. So next remove the wire on the "W" terminal on the board. Retry power to the door switch and now nothing should be on except the red lite. If it tries to start the 12 code and blower up again Im pretty sure you have a bad ignition/blower control board.
Posted on Mar 09, 2009
  • 744 Answers
SOURCE: carrier furnace model # 58PAV090-14 fan runs but
See the link:
http://hvac-talk.com/vbb/showthread.php?t=77420
Posted on Mar 19, 2009
  • 400 Answers
SOURCE: Carrier weathermaker sx (58SX)furnace makes a
This can be from a bad connection on a contactor relay. Or can also sometimes indicate a bad capacitor.
Posted on Nov 18, 2009
Carrier infinity furnace 2010 has stuck inducer pressure switch, Can I manually bypass and heat the house until serviceman arrives tomorrow?
I wouldn't bypass any safeties when its part of the exhaust system of the furnace. That is the first safety that acts in the furnaces sequence of operation. The induced draft will initiate and that pressure switch will close, proving the IDM is working and flue is clear. It's primary purpose is to exhaust any fuel that may linger inside the heat exchanger and then to reject the post combustion process. Carbon monoxide becomes an issue. As far as the Infinity, these units will not start if safeties are bypassed. The unit checks all safeties/circuits for continuity, and if a switch is closed when its not supposed to be, it won't allow.
Mar 05, 2017 | Carrier Heating & Cooling
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Code 24 on carrier weathermaker 8000ts
Turn power off to unit. Open air handler and take a picture of the low voltage (tstat) wires and where they are landed. Remove all thermostat wires from control board. Then replace the 5 amp fuse that is likely on the board. Fuse likely looks like one for a car (blade style). Put a jumper (small piece of wire) from the R terminal to the G terminal and turn power back on to unit. This should bring on the indoor blower. Let me know how that goes!!
May 12, 2017 | Heating & Cooling
Carrier 8000 weathermaker 92000 btu
If it works with blower door off sounds like it's not getting enough return. What's the statics? Try an adjustable limit, I think they go to 210. Good Luck!!
Jun 13, 2017 | Carrier Heating & Cooling
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Carrier 38tkb not working, but furnace is blowing
It is probably a capacitor problem. Check inside the outside unit. you will see a round cylinder with three groups of terminals on top. If the top of it is dome shaped it probably needs to be replaced. You can check it if you have a microfared tester. However if it is poofed out it probably is bad. If this is not the problem you will probably have to replace the fan motor.
Jul 07, 2010 | Carrier 38CKC036 Air Conditioner
Furnace won't work because of a loose Inducer Motor Connector
Cut power to the system at the main disconnect.
Turn the gas off at the unit.
remove the panel, andsee if the stakon conection is intact. Chances are its just a loose connection from your description.
If the problem is not obviose, let us know what you did or did not find.
Dec 04, 2008 | Heating & Cooling
Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
