Question about GE Washing Machines
G135 washer leaking water
Water is leaking from underneath. the hoses connected to back are not leaking...
jsrock516
  • 5911 Answers
SOURCE: washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
Posted on May 12, 2007
SOURCE: water leaking from underneath after washer drains
I have the same washer and there is a white plastic piece underneath the washer where two hoses go into. It contains the impeller that pumps the water out. Anyway, on my machine this piece was incorrectly injection molded at the factory. The glue bubbled out causing an air bubble -- once the air bubble in the glue can stand the pressure and pops, the leak occurs!!!!! If you are a handyperson, take this piece out and use exopy to fix.
Posted on Mar 30, 2008
JULIANFIX
  • 975 Answers
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
SOURCE: Whirlpool Cabrio Leaks Water
you probably got coins or junk in the water pump on the bottom back of washer and it poked a hole in the housing. Thats what happened to me
Posted on Sep 16, 2008
  • 25 Answers
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check http://www.applianceaid.com/genew.html
Yours Truly,
Mr.Fix-it-guy
Posted on Aug 12, 2009
Mav6451aww
water pump, replace
Sep 24, 2017 | Washing Machines
Leaks from underneath
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Kenmore Elite Washing Machines
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Cold water hose or seal leak inside machine leaks into basin
Replace the water inlet valve. That is where the hoses connect.
Here is a link to show you how to access the inside of the washer..
Mar 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leaks water onto floor while in use
It sounds like a water hose is leaking or has a split in it. Check the water in-take hoses on the back of the washing macine, to see if its leaking or split. If they are leaking, unscrew the hose and check or replace the rubber washer, thats in the brass screw-in part. Next, unplug the washer power cord, unscrew the intake water hoses that are in the back and turn the washer on it's side and check the water hoses underneath the washer. They may be loose or split. Any hardware store should have these hoses in stock, like Lowes or Home Dept, or your local "Do it center".
Jan 19, 2009 | Washing Machines
Kenmore 22992 top load washer
Remove the front panel and youll see.
May 20, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
51 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
