Question about Linksys WUSB54GC 802.11g/b Wireless Adapter
Wireless n gaming adapter not working with wireless b router
Wireless n gaming adapter reading wireless b router as a wireless g...reading different ip address....works with the computer but not the xbox 360
First off, some wireless G routers also support B mode. You should use your SSID to be sure you're on the right network. Lastly, this adapter will not work in a 360. This adapter is designed only for use in a Windows based PC, however, drivers have been written, unofficially, for Linux and MacOS. Linksys will not support these drivers though.
Posted on Sep 18, 2009
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 127 Answers
I suggest you to type all wireless settings that you have on the router manually in the wireless settings of your xbox 360.also depands on the security compatibility between your router and your adapter,i mean to say try wep and wpa.and your wireless adapter is reading your wireless router as G because it`s of G standard(adapter).try putting all wireless settings manually and it should work.
hope that will help you.
Posted on Jun 13, 2009
Asus ac68u router is not working with my powerline adapter. The router is brand new and less than a year old. The powerline adapter are tp link 500mpbs model tl-pa411. I have tried directly connecting
HAVE YOU DONE A VOLTAGE CHECK ON THE ADAPTER? IF NOT, READ WHAT THE VOLTAGE ADAPTER OUTPUT IS. IF THE MEASUREMENT IS DIFFERENT OR DON'T GET A READING AT ALL IT MEANS YOU HAVE AN OPEN CIRCUIT ON THE ADAPTER. MOSTLY MOST WIRES BREAK UNSEEN INSIDE THE PLASTIC INSULATOR NEAR THE PLUG END OR NEAR THE ADAPTER END, WHERE THEY BEND MOST.
Oct 28, 2014 | ASUS RT-AC68U Dual-band Wireless-AC1900...
I got belkin wireless g gaming adapter for my xbox 360 the other day and i downloadaded the cd on my computer and followed the instructions, but when i put it in my xbox 360 the xbox couldnot find the...
You will need to match the wireless settings of your router and the gaming adapter.
Who is the manufacturer of your router?
connect your computer to the router with the cable and open the set up page of the router. check the wireless settings of the router SSID, Channel, security settings.
now you gaming adapter and the Router IP address should be in the same range. Suppose if the router IP address is 192.168.x.y and the default IP address of the gaming adapter is 192.168.a.b., then the number x should be equal to a. If it is not then you will need to change the IP address of the gaming adapter so that x will be equal to a.
after that open the set up page of the gaming adapter and change the wireless settings.
power cycle the router and the gaming adapter and now it should work.
For more info about networking Click Here
Oct 06, 2009 | Belkin (F5D7011) 802.11g/b Wireless...
Same issue, cannot connect to my wireless connection at home...
1.Try upgrading the firmware on your router
2.unplug your router and/or modem and plug back in see if that makes any difference
3.connect gaming adapter directly to the computer, reset gaming adapter back to factory default settings, assign a static IP address on computer, for e.g. 192.168.1.10 subnet mask 255.255.255.0 default gateway to 192.168.1.1, logon to gaming adapter's setup page and edit the the wireless settings and IP address according to wireless router or Access Point and save the settings...remove the static IP from the computer and power cycle the n/w...open or trigger 10070-10080, 6000-6999 ports on the router for PS3 and check whether it works or not.
Jul 25, 2009 | Sony Playstation 3 (PS3) Console
Linksys dual-band wireless-n gaming adapter + westell versalink
put all the adresses and getways(on xbox internet setings same as pc then it should work
Mar 25, 2009 | Linksys Dual-Band Wireless-N Gaming...
Wireless driver can not read my wireless router
If you're having trouble with a router, it most likely has nothing to do with your laptop at all. If there is a problem with your laptop's wireless adapter, you may be able to find updated wireless drivers through the laptop manufacturer.
Please keep in mind that a wireless router and wireless adapter are completely different. The router is external and relays the signal from your modem (the internet) to your connected PCs. The adapter is in your laptop and sends/receives information from wireless routers such as yours.
Mar 04, 2009 | 2wire HomePortal 1800HG Router...
Connecting wireless
Based on the category you picked I need to ask if you want to connect a wireless adapter in a computer to the one wireless router you have or do you have such a large area that you need two wireless routers to cover the space. They are two very different issues. Please add a comment to this issue if you really have two routers -- it is a different problem than the one I will describe.
Assuming the picture of the device is right and it is another wireless adapter you need to connect to the router.-- the simple answer is basically the same as the ones before which is probably not helpful now. (Assuming the wireless adapter is installed and the drivers loaded.) Then if you have an secure network (where WEP or WPA was enabled) you probably will need to connect to the specific network using your adapters manufacturer's software or Windows Wireless Zero Configuration where you will probably need to supply a network name (SSID) and the passphrase that was configured inro the router. If you have an unsecured network your adapter may work without configuration. There is one other possible issue -- most routers dynamically assign ip address and other information to the adapters. If your router was not configured to supply all information including DNS addresses we may have some additional configuration to apply to the wireless adapter.
Please respond if these steps are two complex so I can provide additional information. Please provide the manufacturer and model of the wireless router and wireless adapter if that is the case so I can provide more detailed information specific to your hardware.
Jan 04, 2008 | Linksys Wireless-G WGA54G 802.11g/b...
HELP PLZ setting up o a 2wire router with gaming adapter
Could it be possible that the game adapter is out of range of your router?
Dec 29, 2007 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Gamin adapter set up, plz help
Hi Shawn. Does yout PS2 connect when it is downstairs on the wireless? Reason I ask is wifi routers tend to transmit horizontally, and are very weak in vertical transmittions.
If you are connecting while you are own stairs, we can assume the WEP is not an issue.
WEP setting vary on different adapters. Some allow your to use 5 digits for your wep code, others require the full 10 digits. If you are using just 5, say 12345, try putting a 3 infront of each digit, i.e. 3132333435. If you are using all 10, on bought the adapters, this shouldn't be a issue.
Of course, if you can connect to while downstaris, this issue it mute.
You can also try changing channels. Channel 1 has more range than channel 8.
The last guess is that yoour router has less range than the Dlink.
See if any of those suggestions help, and let us know.
Good luck.
Dec 29, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
Hooking up my gaming router
There is a 90 % possibility that the wireless settings on the gaming adapter and the router are not the same. Try to reconfigure this again. Remember that the gaming adapter's wireless settings needs to synchronize with that of the router to make the gaming adpater works. Call netgear and verify the settings on your wireless connection and reverify the settings you have on the adapter. For manual instructions, see user guide at www.linksys.com/download
Oct 15, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
Linksys WUSB54GC 802.11g/b Wireless Adapter Logo
315 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
