Question about Mitsubishi VS-50607 50" Rear Projection Television
TV immediately clicks & turns off
When trying to turn on TV it clicks, flashes the timer light & goes off. Is this the code 24 problem & how do we fix it. Upon pressing menu & input the timer flashes twice then four times pls help if you can. Thank you.
  • 1153 Answers
SOURCE: 50707 does not turn on, goes off immediately code 24, relay clicks
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Posted on Aug 27, 2007
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi 56 inch rear projection TV
A 22 code in Mitsubishi is a short circuit that is causing your set to go into protective shut down. Check the horizontal output and low voltage regulators for being shorted. Let me know if I can help you further, or if you need any additional info.
Posted on Jan 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WT-46809 Vertical Deflection Failure
the vertical output IC may need re-soldering or it may be defective and need to be replaced. my guess would be bad solder on the vertical IC.
Posted on Apr 23, 2008
SOURCE: Mitsubishi Medallion does this
may be there will be some loose connections inside you need to find and should solter it ............if warranty is there go for it...................because repairing by own will void warranty
Posted on May 26, 2008
premtech
  • 934 Answers
SOURCE: Flashing timer light, cannot turn on tv
Press and hold "Device" and "Menu" buttons for six seconds and see if you then get a patter of flashes pertaining to the error codes... I would suspect one of the following codes:
12 No Error Detected
22 Recovery From Momentary Reset
32 Lamp Cover Open
33 Air Filter Cover Open
34 Lamp Abnormality
35 Chassis Fan Failure
36 Exhaust (Back Cover) Or Lamp Ballast Fan Failure
37 Engine (Dmd Or Lamp) Fan Failure
38 Excess Lamp Temperature
39 Excess Dmd Temperature
41 Short Detected
44 Dvi Cable (Between Chassis And Engine) Disconnected
Bill
Posted on Sep 27, 2008
Sont tv model#kv-32hs420
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. Check this link for more details.http://electronicshelponline.blogspot.com/ Pull up older posts. Blinking codes to Sony TVs are given in detail.
Jun 05, 2013 | Televison & Video
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
While setting up the Crest Universal remote control RCP1F for my sharp TV, I've managed to turn the TV off, but now I can't turn it back on. The TV remains on Standby and turning off the power doesn't do...
OKAY TRY THIS..
DO STEPS 1-3 AGAIN AND ONCE IT TURNS OFF KEEP CLICKING THE CURSOR UP A COUPLE TIMES.
THEN START CLICKING THE CURSOR DOWN SLOWLY TELL THE TV TURNS BACK ON AND ONCE IT CLICKS BACK ON HIT THE TV BUTTON ON THE TOP OF THE REMOTE ..
IF THE LIGHT BLINKS TWO OR THREE TIMES MORE THEN LIKELY YOU'VE PROGRAMED IT =)
AND NOW KICK BACK RELAX AND ENJOY A COLD BEER FOR THE BOTH OF US =)
Nov 18, 2010 | Televison & Video
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
Try to turn on, it turns off right away and the stand by light flashes 6 times
Hi
Thanks for using FixYa. Standby/Timer light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. Also check +5 line is overloaded (A, B boards), +5 line is shorted (A, B boards). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
I have a sony wega
Generally speaking whent he set shuts itself down, the standby light will blink a code. This will be a count followed by a short pause and then the count again etc.
When teh set shuts down, count the blinks and post it here. That will indicate the circuit that has the problem.
Dan
Dec 05, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Well, I have found out that the number of red light blinks is a "blink code" that indicates the nature of the fault with the TV. Usually these are various failures of internal fuses or circuit boards. There's a fair amount of information on threads at techlore.com on this, so try searching there. Teh specific codes and manuals are usually it seems under license from Sony and not available for free to the public. Sorry!
Oct 17, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Mitsubishi VS-50607 50" Rear Projection Television Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
