Question about Eureka Mega Boss 4460DT Vacuum
Eureka boss manual
Sucktion is great belts good no clogs but it won't pick up debit do u think so need a new roller
reddevil6
  • 1673 Answers
SOURCE: How to change belt on Eureka Whirlwind
On the top cover, there are holes at the front on both sides, there is a screw on each side in one of the holes. Take the out, and the cover should come off, then you can get to the brush roll and belt.
Posted on Jan 29, 2008
SOURCE: My Eureka Boss vacuum belt keeps breaking
I have been searching the machine for something which could be rubbing against the belt to cause it to fray and break as often as it does. So far, I haven't found anything. I have heard that the belts, called ribbon belts, are terrible! I find that the belts break faster when I use the hose. I haven't found a way to make a belt last longer.
Posted on Jul 10, 2009
susho
  • 18 Answers
SOURCE: Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Posted on Jul 31, 2009
SOURCE: Eureka boss power plus
I had this same problem. The brush roll wouldn't spin, smoke came out, and it smelled like burning rubber. I changed the belt thinking that would fix the problem but it didn't, so I took the belt back off and checked the motor shaft in the back and found a whole bunch of hair wrapped around the shaft. Once I cut out the hair with some scissors and replaced the belt, everything worked like normal. I hope this helps.
Posted on Sep 20, 2009
  • 69 Answers
SOURCE: new eureka vacuum has not real suction
Is the belt slipping. Are all the seals good
Posted on Mar 27, 2010
Why does my vacuum leave a trail of hair on my floors when it's being pulled backward but suction up fine when it's going forward?
It is because the belt is worn and stretched. when you go forward there isn' t as much resistance and the brush can turn and pick up, but when you go back there is more resistance and doesn't pick up. You simply need to replace the belt. Here is the belt you need:
Eureka Boss 5849 Belts
May 20, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka the Boss Power Plus belt problem
it could be the beater bar (brush) has bad bearings at the ends or burs on the beater bar section the belt rides on,my money is on the bearings.
Jan 24, 2010 | Vacuums
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Is the roller brush supposed to turn when the power is on?? the sucktion is on but the brush doesnt roll
That means that you need to replace the belt which turns the roller brush. Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Jan 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
My Eureka The boss Smartvac Model #4870 roller brush won't turn even on the highest setting and the belt smells hot. we took the belt off. How can you tell if it needs replaced?
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Dec 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How do I replace the belt on my eurika vacuum it is a boss model.
Did you say that you have a Eureka? Also you need to know the model number because belt changing methods and belt sizes vary depending on the model. You can find the model number on the vacuum and can find the belt you need in the manual. Then you can get any Eureka belt here:
http://vacbelts.com/index.htm
Oct 28, 2009 | Emerson Vacuums
I have a eureka the boss smart vac petlover vacuum and I cannot find the book on how to replace the belt. I have opened it up, but there is a silver roller that is confusing me.
Either go directly to the Eureka internet site, or GOOGLE "eureka boss smart pet lover manual". Several options should be displayed to download the needed manual.
Oct 10, 2009 | Vacuums
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
I'm using (or WAS using) a Eureka ''the boss'' model 8803. The belt broke, no biggie, so I replaced it with a Eureka model U belt, the problem is when I put the new belt on and turn on the vaccuum, the...
First, make sure you have the right belt, second, i am thinking that you are not lineing the roller up right, it will only fit one way. look at the ends of the roller and the grooves where it slides in, you should be able to see clearly how it goes.
Jul 26, 2009 | Vacuums
Eureka Boss Model 4703 Type Belt Problem
Belt can be purchased from amazon, click here and take a look: Amazon com eureka boss vacuum belt. I hope this was helpful. Cheers
Apr 11, 2009 | Vacuums
Eureka Mega Boss 4460DT Vacuum Logo
49 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
