Question about Whirlpool MH3184XP Microwave Oven
Whirlpool microwave model GH5184XPB-4 F7 code what is this?
An F7 error code comes up on the microwave, what does this mean?
bestdarngood
  • 3037 Answers
SOURCE: whirlpool microwave oven model gh5184xpq
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Please let me know if you need any more help or have further questions about anything that I have posted. I would be glad to help
thanks
Posted on Apr 27, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Whirlpool Velos Microwave showing "Error
F7 means that the control panel is not getting feedback from the Switched Mode Power Supply (high-voltage inverter).
This could be due to a problem with the inverter or the control unit / circuit board, but it appears to be the latter in most cases.
We repair microwave control boards for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful.
You may reply back with your brand and model number if you'd like us to look into this further, or feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 29, 2008
vitg55
  • 78 Answers
SOURCE: f7 Error
This is schematic:
http://www.servicematters.com/docs/wiring/wiring_main.htm
But your correct model # is: GH5184XPS4
F7 Power to magnetron
interrupted
1. Check the door, hinge and cavity front alignment. Adjust as needed.
3. To check the over-temperature protection for the magnetron, unplug
microwave oven or disconnect power.
4. After 40 seconds, check to see whether this solves the problem.
5. If this solves the problem, check the cooling fan for proper operation or
blockage.
6. Unplug microwave oven or disconnect power.
7. Check resistance of the magnetron thermostat. It should be close to
0 ohms. If necessary, replace magnetron thermostat.
8. Check that the control cable to the 1100 watt inverter is correctly connected
to plug P2 on the display PCB. If necessary, adjust or reconnect.
9. If interlock switches operate correctly, replace 1100W inverter.
10. If problem persists, replace electronic control.
11. Plug in microwave oven or reconnect power.
Posted on Dec 07, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: we have a whirlpool GH5184XPS-4
From the technical sheet usually located behind the control panel or grille:
F7 Power to magnetron interrupted
3. To check the over-temperature protection for the magnetron, unplug microwave oven or disconnect power.
5. If this solves the problem, check the cooling fan for proper operation or blockage.
7. Check resistance of the magnetron thermostat. It should be close to 0 ohms. If necessary, replace magnetron thermostat.
8. Check that the control cable to the 1100 watt inverter is correctly connected to plug P2 on the display PCB. If necessary, adjust or reconnect.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
ZJLimited
  • 17970 Answers
SOURCE: I have a whirlpool microwave oven over the range.
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Posted on Apr 12, 2011
I have a Kenmore Elite Speedcook Microwave oven, model #665.63783600. What does error code F7 mean on this model?
F7 Error Code On Microwave Ovens With Inverter Board
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
For more free help, feel free to contact me via my site with your detailed symptoms and full model number and FCC ID number as shown on the tag in or on the oven.
Nov 18, 2016 | Kenmore Microwave Ovens
Whirlpool microwave oven model gh5184xpq
KHHS178L KHHS179L
Possible reasons:
as needed.
the problem
blockage
inverter.
thanks
Apr 27, 2008 | Whirlpool GH9185XL Microwave Oven
Code f 7
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. It should cover an F7 error code.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This may help:
MODELS: GH9177XL, GH9185XL, MH9180XL, MH7155XMS, & KHHS178L for example
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Whirlpool Microwave Ovens
Whirlpool gold GH5184XPB-4 Last used to cook potatoes. sensing then cooked. Now runs but does not cook. Any ideas? Joe
There are three reasons for this, a bad magnetron "common problem" or a high voltage diode and capacitor can be a factor. If the magnetron is at fault it is cheaper to replace the microwave oven.
Mar 10, 2011 | Whirlpool Microwave Ovens
Error code F7
Hi drk2676,
This error code F7 means that you have a function key stuck on ERC. You can solve this issue by replacing control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Feb 01, 2011 | Whirlpool GH6177XPS Microwave Oven
F7 ERROR CODE ON GH6177XPS
This is a known problem with this unit, and whirlpool has put out a Service Flash out on this. The reason this is happening is Electrical circuit interruption between the L1 and Neutral in the microwave invert circuit. This has to be addressed by a Tech.
DrakeTech
Dec 24, 2009 | Whirlpool GH6177XPS Microwave Oven
Error F7
Possible reasons:
as needed.
the problem
blockage
inverter.
Nov 18, 2009 | Whirlpool GH9176XMS 1100 Watts Microwave...
Whirlpool MH3184XP Microwave Oven Logo
43 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
