Question about Dual XDVD8181 Car Video Player
Xdvd710 in dash dvd player (dual)
K the yellow wire for the dvd player that goes to the e-brake how do i by pass this?? My e-brake switch only has one wire going to it and the switch is grounded to the floor of the truck so what do i do???? Some say a toggle switch but how will this work with a toggle switch.
  • carey harrison Mar 30, 2009
    is there a way to make it work
My ratio has the flip up monitor the ratio works but the screen is black and white lines it's the dual xdvd710 and I enter know how to fix it
Posted on Dec 05, 2011
Hey..All i did was cut the end..put a new End on and bolted/grounded it to the frame..and you can watch movies while driving.
Posted on Sep 11, 2008
Bought a dvd player xdvd710 from the pawn shop.Got everything going ok.Turned to serius radio and cant get it back on regular radio tuner.It did not come with instructions.help please,
(ninja)
Posted on Mar 03, 2008
Ground it
Posted on Nov 03, 2007
Just ground the yellow blue wire
Posted on Oct 14, 2007
Just hooked up dual xdvd710 but all it does is the button blinks red and beeps. What is wrong?
it sounds like a wiring problem i have seen these in many in dash dvd players. if you still have the manual just check your connections and your grounds there may be a short or mis matched wire
May 14, 2011 | Dual XDVD8181 Car Video Player
Try to bypass a emergeny brake pedal switch for a touch sceen dvd player radio. Its a dual model xdvd710
TRY GROUNDING THE WIRE THAT HAS TO BE HOOK TO THE E BRAKE YOU MAY EVEN HAVE TO GET A SWITCH AN ON AND SWITCH THAT MIGHT WORK EVERY DECK IS NOT THE SAME
Feb 19, 2011 | Dual Electronics XDVD710 Car DVD Player
How do u unlock a dual xdvd700 radio to watch movies
you need a switch so you watch tv it only cost about $5.00 just hook it up to your yellow wire and ground it and your done
Oct 01, 2010 | Dual Electronics XDVD710 Car DVD Player
How do i hook up my parking brake wire on my xdvd710
The yellow/blue wire out the back of the head unit needs to be hooked up to the same wire that is responsible for illuminating the "BRAKE" light on your dash. This tells the DVD player that the car is not in motion. Where this wire is and how to tap into it is entirely dependent on what kind of car you have. You may need to trace the wire out or consult a wiring diagram.
If you wish to bypass this feature (which may be illegal in some states) try this:
** Insert a DVD
** Let it play until you hear sound
** Press STOP twice on remote
** Enter 26604
** Press ENTER
Feb 26, 2010 | Dual Car Audio & Video
How to bypass a dual xdvd710 without the remote
ground the brake wire from the radio to a switch that cut off and on, to the chassis ground you will have to hit the switch every time you want to watch the tv the switch acts like its hook up to the parking brake so when u hit it twice it thinks that the brake is engage
Oct 09, 2009 | Dual XDVD8170 Car DVD Player
Dual xdvd710
check on the main wiring harness you wil see a black box on the yellow wire. open up the cover. there is a 10 amp mini fuse inside. if it is blown replace the fuse. also check your main radio and accesssory fuses in your fuse box. if no fuses are blown check all wiring connections.
Jan 31, 2009 | Dual XDVD8181 Car Video Player
Dual XDVD710 Car Video Player
There isn't a code but there is a way when you wire it. DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 31, 2008 | Dual XDVD8181 Car Video Player
How to by pass the e brake wire
OK PEOPLE, I HAVE THE DUAL XDVD8181 just installed, you don't need to do any kind of code to get the video to bypass. this is what you have to do
Get a toggle switch, one that flips one way for ON, and the other way for OFF. connect parking brake wire (yellow/blue) to one end of the switch and the other end to the ground of the radio (Black wire) leave the switch in off position, turn on radio and insert dvd, when you get the blue screen, flip switch ON OFF ON wait 5 seconds and video will come on. That it fellas.
Dec 11, 2007 | Dual XDVD8181 Car Video Player
Dual xdvd710
find the memory wire [yellow] and make sure you connect it right if that isnt the problem check fuse box or make sure your remote is not hooked there
Nov 13, 2007 | Dual XDVD8181 Car Video Player
all you have to do for you to be able to play video while driving is... take the yellow wire with blue strip and wrap it with your ground wire and connect the ground wire to a GOOD chasie ground
Sep 13, 2007 | Dual XDVD8181 Car Video Player
Dual XDVD8181 Car Video Player Logo
603 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
