Question about Air Cool AC436-GB Fan
Upc remote 792145350989 - Air Cool AC436-GB Fan
2 Suggested Answers
SOURCE: how do you find the remote for this UPC 792145350989 Fan Remote
Go to home depot
Posted on Mar 14, 2011
I need a code for a blue diamond tv model number BD40DL fev10
Remote Code for Blue Diamond TV - Boards.ie
www.boards.ie > Talk to... > Sky Ireland
Aug 7, 2015 - After checking our database for remote codes we don't have a codeavailable for your particular make of TV, Blue Diamond. I will be sending ...
Horizon UPC Blue Diamond LED Remote Control - boards.ie
www.boards.ie > ... > Cable & Digital TV > Cable & MMDS & IPTV
Dec 11, 2013 - I have bought a BLue Diamond TV and upgraded to UPC Horizon HD. ... the code for Mitsubishi who from what I can see make Blue Diamond Sky Remote COde
May 29, 2015
Anyone code for programming sky remote bluediamond tv?
Dec 10, 2012
More results from www.boards.ie
Dec 10, 2015 | Televison & Video
Upc flashes four times
Check the remote control for its infrared emission. It sounds like the infrared emitting LED at the front of the remote control is not functioning well. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
One among the posts by this site, have details about how to check a remote control. If you wish to get sett-up codes and other details, check this site. http://electrohelponline.blogspot.com/
Mar 21, 2014 | One For All URC-3445 Remote Control
I want to operate a upc remote control with a sky digibox. Does anyone know what code i use on the remote.
I have a tv set called meister ; can I have the code for setting my upc remote to controll the tv?
Apr 11, 2010 | Televison & Video
I cannot reverse the fan blades
look for a small slide switch around the body of the fan. most fans have a small switch to reverse direction.
good luck....jay
Apr 22, 2009 | Air Cool AC436-GB Fan
Remote no longer works
In side of the TV set there is a remote receiver module. In some models of sets, there is no module. They use descrete components on the main circuit board. The fault could be in the remote receiver section. In some models of TV sets there are some remote amplifiation circuits along the way to the uPC controler. There could be a fault along this path.
The service tech would troubleshoot this by verifying the voltage supply to the remote receiver circuits. Then he would shoot an IR remote signal to the receiver, and then follow the data flow from the output of the IR reciever circuits along its signal path to the uPC controler. This way, he should be able to see with the scope where the data signal is failing.
Jerry G.
Oct 01, 2008 | Philips Magnavox 20MS233S 20" TV
Remote is inop
A universal remote is not a reliable way to test a remote control. If you can have an original remote this is the best way to test the remote function of the set. Or, if you have another set that is the same model as yours to test a universal remote, then the test would be acceptable.
If the remote has failed on the TV side, this can be from a number of problems in the set. It can be the remote IR sensor module itself, or one of the buffer amplifier stages on the way to the uPC, or the uPC itself. In some models the buffer amp is built in to the IR sensor module.
Without properly troubleshooting this fault, there is no possible way to actualy determine the point of failure. More than 90% of the time, the failure is the remote. Remotes get dropped, and abused often, and therefore they are subject to a high degree of failure.
Did you try unplugging the set from the AC mains for at least 15 to 20 seconds? This will cause a reset to occure for the uPC. If the fault is still there the set and the remote control will need a proper follow-up to service it.
Jerry G.
Apr 19, 2008 | Toshiba 32A43 32" TV
Symphonic b-19wm
It can be the remote sensor, or the circuitry that works with it. I don't know its exact location for your model, but you can usualy find it, because at its location it looks like a little black or dark red window in front of it.
The sensor and its related circuitry are servicable. To find the exact fault will require using a DVM and an oscilloscope to trace down where the signal is stopping from the sensor. The sensor feeds the main uPC controler via a number of components on the circuit board. An experienced service tech should be able to troubleshoot this for you, and replace the defective parts. On rare occasions the fault can be with the uPC itself.
It is also possible that there is a cold solder connection on the circuit board that is stopping the remote sensor from getting the remote signals to the uPC.
Jerry G.
Apr 11, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Air Cool AC436-GB Fan Logo
66 people viewed this question
Top Air Cool Dryers Experts
Dan Webster
Dan Webster
Are you an Air Cool Dryer Expert? Answer questions, earn points and help others
