Question about Humminbird Piranhamax 220 Fishfinder
Cut cable between probe and viewer. Can cable be
Cut cable between probe and viewer. Can cable be repaired?
  • 74 Answers
In a pinch, probably. For long term, no. ther eason being that you cannot get a good enough connection on the jacketed cable to make the sounder work properly. That and the fact that there is alot of voltage running through the wire!
Best to replace it.
Mike
Posted on Sep 27, 2009
2005 pontiac vibe new starter new battery and still won't start and won't engage the fly wheel. It does nothing. 1 click.
Check the 30 amp MAIN fuse.
Is the security light flashing?
If not, could be neutral safety switch.
I would probe the ST relay socket to see if anti-theft is turning on the starter cut relay. You could also probe that relay socket.
Do It Yourself Diagnosis and Repair
Aug 26, 2017 | Pontiac Cars & Trucks
PowerPoint Viewer error 32-bit
Try PowerPoint Repair Toolbox is powerful .PPT repair software, resolving any problem, causing the damage of PowerPoint files.
For more: https://www.pptrepairtoolbox.com/
Apr 09, 2015 | Microsoft Office Professional 2007 Full...
1999 cadillac seville wiring diagram
Check wiring with a test light or volt meter. switch lights to low beam, connect volt meter N probe to a good ground then probe the light socket for the low beam power cable, should show battery voltage, now switch to high beam and test for battery voltage if ok remove the grounded meter probe and probe the cable in the socket that you have not tested this is the ground cable, battery voltage should show if ground cable is ok. If no voltage repair cable ,If voltage present check filament on bulb high beam perhaps the new bulb is faulty.
Jul 10, 2014 | 1999 Cadillac Seville
Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
How would you find a short in a car. It is draining my battery at night?
Remove the negative battery cable from its post and connect an ammeter red probe to the negative battery post and the black probe to the negative battery cable. Now start pulling fuses until the voltage on the meter returns to normal. (anything above a half of a volt is too high) The fuse you pulled to get this result is the affected circuit. Now you have to probe it from its B+ source to the load
to find the short. Check all connectors for rust and the line for opens or shorting to ground. Repair accordingly.
Jan 04, 2010 | 1996 Toyota Camry
Cannot transfer files from/to PC
Check your USB cable. The cable might be faulty. Ensure that the cable is right.
Aug 21, 2009 | Casio Pocket Viewer PV-S1600
Imobaliser and distributer problem on a v6 ford probe m reg
sounds like your immobilizer is giving you trouble i don't think you'd need to reprogram for a distributor if it worked for a week, your only option is bring to dealer to have immobilizer checked out please rate -jeff
Sep 04, 2008 | 1994 Ford Probe
Fuel cut off light
there is a fuse and a relay that need to be checked they are located in the fuse box under the hood. if there is a cut off it will be located in the trunk behind the fabric.
Jul 29, 2008 | 1995 Ford Probe
How do I replace the probe
Yes and no the reason they ask you to cut them is the lenght of the wire does affect some of the probes (thermistor) it reads resistence and the longer the wire the more it will read if you want it to be for sure your model is this type do it the right way and pull the oven if you want to cut it in place then try the oven like that if you are happy with the temps then leave it the reason the wire wont pull out the is a zip strap holding it in the wire bundle behind the back wall.Hope this helps
Jan 21, 2008 | Frigidaire PLEB30T8A Electric Double Oven
Humminbird Piranhamax 220 Fishfinder Logo
142 people viewed this question
Top Humminbird Boating Experts
Phil Walker
Phil Walker
Steve
Steve
fordexpert
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
