Question about Refrigerators
Where is evaporator fan motor in Frigidaire model FRT21IL4FW8
Evaporator fan motor in Frigidaire model FRT21IL4FW8
SOURCE: BM-23 Evaporator fan motor
mine runs all the time.
Posted on Jul 02, 2007
the dr
  • 447 Answers
SOURCE: inside fan motor - evaporator
Yes if you dont hear the evap fan wprking remove rear panel in freezer let me know what you see. Is coil iced over? Is fan running? Is the motor warm? Attempt to spin the blade gently to see if the motor is bound. You can oil these.
Posted on Dec 02, 2007
SOURCE: Evaporator fan did not start running when condenser fan started.
I don't know why there would be much of a delay between the condenser and evaporator fans coming on. If you have diagnosed it as a bad motor, that's probably correct.
But the motor could just need cleaning and lubricating
Posted on Apr 28, 2009
BIKER T
  • 909 Answers
SOURCE: Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
Posted on May 23, 2010
SOURCE: Evaporator fan new but not working on samsung rs267lash
Manny MANY unfortunate customers who bought this **** from Samsung have problem.
Specifically the Freezer cold but fridge side no lower than 55deg problem.
It is a known defect that Samsung has not taken ownership of. I have the same problem with the same model as many.. if you search the net. Iv'e been trying to find a designated website for repairs for this problem. Please post website with solution if anyone finds it. Thanks
Posted on Aug 28, 2010
Frigidaire fridge model FGUN2642LF6 fridge is not working. Code displays sy and ef, what is wrong
Your evaporator fan is not spinning.
Check to make sure there isn't any ice build up jamming up the fan. If there isn't then it's either the evaporator fan, or the main board.
Aug 14, 2015 | Frigidaire Refrigerators
My Frigidaire brand refrigerator blower motor does not come on. Where is it located in this refrigerator?
Your evaporator fan is located in the back section of the freezer. In this particular model the fan is energized by the ADC(auto defrost Control) which is in the control panel in the fresh food section. Behind the thermostats. The red wire with a white tracer is the power feed to the fan from this control. The condenser fan is beside the compressor in the back of the unit.
Mar 03, 2015 | Frigidaire Refrigerators
Working but extremely noisy freezer
most likely noise is coming from evaporator fan motor.go here,it will show you the parts in your model,
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Freezer-Parts/Model-PLFU1778ES0/1428/0142000/R0510085/00002?blt=06&prst=&shdMod=
unplug the freezer,remove shelves and remove back inside wall to get at the fan motor.you might see yellow stains around motor area,that's from the oil that leaked out of fan motor,also if noise stops and you notice that the freezer is cold on bottom and warm on top the fan motor died and needs to be replaced right away.hope this helps and you should change the motor out before you loose any food.
Dec 08, 2013 | Frigidaire PLFU1778ES (16.7 cu. ft.)...
Evaporator fan is not working and temp in freezer is not working but the coils are working
You will need to replace the evaporator fan assembly. I didn't see your model number posted but here is a link to the Frigidaire fan kit that should cover all models.
Sep 03, 2012 | Frigidaire Refrigerators
After power outage the fridge was displaying codes SY and EF I have Frigidaire model number FGHS2365KF1. Any thoughts?????
Hi.
SY: Defective evaporator system. Check evaporator fan, thermostat and heater.
EF: Evaporator Fan defective. Test and eventually replace the evaporator fan.
The problem is likely the evaporator fan. Before replacing the fan test the other parts comprised in the evaporator system.
Here a tip explaining how to test such parts with a similar fridge model: Fridge not cooling. Procedure is more or less the same with your model.
Here parts and diagrams for your model.
Generally you can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Aug 29, 2011 | Frigidaire FRS3R5EMB Side by Side...
How do I change the evaporator fan motor in a frigidaire model FRS20WNF side by side refrigerator?
This link should be close Evaporator fan replacement You can also enter your model # for diagrams and illustrations of your specific model.
Dec 01, 2010 | Refrigerators
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Not cooling on the fridge side
Remove the lower freezer panel . You should see the fan there . The part number for the fan motor is 5304445861
Aug 29, 2009 | Kenmore Refrigerators
Model FCD-123 Frigidaire malfunction
2 possible issues .evaporator fan motor is not working.you should be able to hear it in freezer.auto defrost is not working and vents are clogged with ice.look for ice/frost buildup on freezer wall///floor
Jun 25, 2009 | Refrigerators
MY BROTHER HAS A FRIGIDAIRE REFRIDGERATOR MODEL NUMBER. FRS3HR5HW3 AND IT IS MAKING A GRINDING SOUND KIND OF IN THE FREEZER. WAS WONDERING WHAT IT CUD BE AND HOW TO FIX IT.
I am having the same problem. I had a technician check it out and he replaced the evaporator fan motor. A month later the noise returned. The technician came again and said the cause was the water valve freezing and the ice buildup hitting the evaporator fan. I am having my brother repair it this weekend. The cost for the tech. was nearly $300, almost a third the value of the fridge. I, personally think there is a design flaw in the refrigeration system.
Apr 29, 2009 | Frigidaire Model: FRS3HR5HW
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
