Question about Frigidaire Refrigerators
Replace evaporator fan in Frigidaire model FRT21IL4FW8
How to get to the evaporator fan motor in model FRT21IL4FW8
SOURCE: BM-23 Evaporator fan motor
mine runs all the time.
Posted on Jul 02, 2007
SOURCE: Evaporator fan did not start running when condenser fan started.
I don't know why there would be much of a delay between the condenser and evaporator fans coming on. If you have diagnosed it as a bad motor, that's probably correct.
But the motor could just need cleaning and lubricating
Posted on Apr 28, 2009
aasc
  • 1606 Answers
SOURCE: New evaporator fan not running smoothly
Great ! ! Usually the main control board is the problem , when the evap fan doesn't run .
Posted on Sep 07, 2009
BIKER T
  • 909 Answers
SOURCE: Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
Posted on May 23, 2010
SOURCE: Evaporator fan new but not working on samsung rs267lash
Manny MANY unfortunate customers who bought this **** from Samsung have problem.
Specifically the Freezer cold but fridge side no lower than 55deg problem.
It is a known defect that Samsung has not taken ownership of. I have the same problem with the same model as many.. if you search the net. Iv'e been trying to find a designated website for repairs for this problem. Please post website with solution if anyone finds it. Thanks
Posted on Aug 28, 2010
Control panel displays 5y ef Model #FGHS2655PF5A
This error is a SY EF (system evaporator fault). The evaporator sensor is not reading enough air flow through the system. The problem could be the evaporator sensor or the evaporator motor.
It can also be linked to a faulty control board. To rule out a problem between the fan and the control board, you can check for 12V DC between the brown and the red wires. You can also check for voltage variations between the yellow and brown wires. (This voltage will depend on if the fan is on high or low speed.) If the voltages are good, replace the motor. If the voltages are faulty, replace the control board.
If you can hear the evaporator running and feel air moving in the freezer, the sensor is more likely to be faulty. (The evaporator is inside the freezer at the back.)
The parts diagrams for the FGHS2655PF5A evaporator is here: http://www.searspartsdirect.com/model-number/fghs2655pf5a/1428/0165000.html . Parts are available from other vendors as well. https://www.repairclinic.com/Shop-For-Parts/a4b2d1933346/Model-FGHS2655PF5A-Frigidaire-Refrigerator-Parts is one alternate vendor.
I hope this helps.
Jan 07, 2017 | Refrigerators
Working but extremely noisy freezer
most likely noise is coming from evaporator fan motor.go here,it will show you the parts in your model,
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Freezer-Parts/Model-PLFU1778ES0/1428/0142000/R0510085/00002?blt=06&prst=&shdMod=
unplug the freezer,remove shelves and remove back inside wall to get at the fan motor.you might see yellow stains around motor area,that's from the oil that leaked out of fan motor,also if noise stops and you notice that the freezer is cold on bottom and warm on top the fan motor died and needs to be replaced right away.hope this helps and you should change the motor out before you loose any food.
Dec 08, 2013 | Frigidaire PLFU1778ES (16.7 cu. ft.)...
Evaporator fan is not working and temp in freezer is not working but the coils are working
You will need to replace the evaporator fan assembly. I didn't see your model number posted but here is a link to the Frigidaire fan kit that should cover all models.
Sep 03, 2012 | Frigidaire Refrigerators
Frigidaire custom imperial 170 manual
replacement compressor for frigidaire refrigerator freezer Custom imperial FPCI-230v3 (20.3 ft vol)
replacement evaporator fan and condenser fan
Jun 11, 2012 | Frigidaire Refrigerators
After power outage the fridge was displaying codes SY and EF I have Frigidaire model number FGHS2365KF1. Any thoughts?????
Hi.
SY: Defective evaporator system. Check evaporator fan, thermostat and heater.
EF: Evaporator Fan defective. Test and eventually replace the evaporator fan.
The problem is likely the evaporator fan. Before replacing the fan test the other parts comprised in the evaporator system.
Here a tip explaining how to test such parts with a similar fridge model: Fridge not cooling. Procedure is more or less the same with your model.
Here parts and diagrams for your model.
Generally you can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Aug 29, 2011 | Frigidaire FRS3R5EMB Side by Side...
How do I change the evaporator fan motor in a frigidaire model FRS20WNF side by side refrigerator?
This link should be close Evaporator fan replacement You can also enter your model # for diagrams and illustrations of your specific model.
Dec 01, 2010 | Refrigerators
#GLHS35E4SB6 Frigidaire side by side. evaporator motor area becomes extremely noisy and eventually shuts off. The fan could be floating on the motor shaft and engaging the shroud. Apparently the...
be sure maybe the sound coming from evaporator fan some times it accumulate ice near it do not open for long time both doors or put hot things inside the fridge or freezer .
Sep 11, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
NEW HIGH SPEED EVAPORATOR FAN MOTOR TOO LOUD Repair technician told me there were problems with the original evaporator motor and replaced it with a new high speed one. Now the fridge is too loud. Before...
It's the rotors making the noise not the motors! I replaced the motor, still made noise, I took off rotor blade sanded it down around each blade, no more high pitched hum!
Jan 12, 2010 | Frigidaire FRS26H5AS Side by Side...
MY BROTHER HAS A FRIGIDAIRE REFRIDGERATOR MODEL NUMBER. FRS3HR5HW3 AND IT IS MAKING A GRINDING SOUND KIND OF IN THE FREEZER. WAS WONDERING WHAT IT CUD BE AND HOW TO FIX IT.
I am having the same problem. I had a technician check it out and he replaced the evaporator fan motor. A month later the noise returned. The technician came again and said the cause was the water valve freezing and the ice buildup hitting the evaporator fan. I am having my brother repair it this weekend. The cost for the tech. was nearly $300, almost a third the value of the fridge. I, personally think there is a design flaw in the refrigeration system.
Apr 29, 2009 | Frigidaire Model: FRS3HR5HW
Refrigerators Logo
22 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
