Question about Acer Aspire Z5600 PC Desktop
Touchscreen Problem Hello! I seem to have problems with my touchscreen as it doesn't work... I had that problem once but I re-installed windows and it worked. But now I've got some important files on here, what can I do... Because it took me ages to do the important things, so nearly anything apart from re-installing will be AWESOME. Cheers.
    Master:
  • 965 Answers
First, you want to back up your files. That way if you have to, then you reinstallxwithoutcloss.is it a hardware issue?
Posted on May 16, 2014
expert007
  • 179 Answers
SOURCE: Hi i have a acer touchscreen and the cd wont stay
change disk drive
Posted on Jul 26, 2010
SOURCE: touchscreen not working
you mean touchpad , right?
go to start button
control panel
mouse icon
adjust touchpad
otherwise would need to find touchpad name and make
start
control panel
system icon
device manager(first on upper left)
scroll down to find touchpad
uninstall
then use new hardware scan in upper left
restart computer
let me know how it works
Posted on May 26, 2012
SOURCE: acer aspire z5600 touchscreen not working
see other solution
maxcarson
  • 7627 Answers
SOURCE: aspire 5600U touchscreen not working
Have you rebooted the machine?
Posted on Feb 23, 2013
SOURCE: Touchscreen not working.
Do you hear a beep when you touch the screen? If you do it is more than likely a software issue, or the cameras are misaligned..
First thing to try is Scroll Lock Calibration.. Press Scroll Lock on your keyboard 5 times quickly, your cursor should move to the top left of your screen, press and hold your finger on it until you hear a beep, remove your finger and itshould automatically move to the top right, repeat for each corner, when it is done the cursor will move to the middle of the screen, and the touch screen should be working
If the computer does not beep when you tocuh the cursor and the cursor does not move when you remove your finger it means your touch is not being recognized... it could be a software or hardware issue, here is one way to find out..
First do a power drain.. shut down the computer and unplug everything from it (including the power cord) and press and hold the power button for 30 seconds.. Now boot the computer into BIOS by tapping F10 on startup.. inside the BIOS touch the screen.. do you hear a beep? if so it is a software issue, if not more than likely it is a hardware issue
A few other things you can try... open the Touch Screen Configuration Tool inside the Control Panel, make suire the touch screen and sound are enabled, select the Troubleshooting tab, click Restore Defaults, try the Calibration function... beyond that you could try System Restore/System Recovery..
Good luck
Posted on Nov 25, 2013
WHY IS MAY TOUCHSCREEN NOT A TOUCHSCREEN ANYMORE..IT IS A GATEWAY ZX4800 ALL IN ONE
You will have to install the drivers for it.
Go to the website of the manufacturer of your pc, Gateway in your case, and search for support- downloads.
Then download the drivers for Windows 8 and install them.
Dec 04, 2014 | Gateway Computers & Internet
Lenovo Flex 15d windows 8.1 touchscreen unresponsive
Hello
Either you have turn the Touch function off or the problem might be with the connection its might be loose. You can check in the control panel for Touch function. Or your keyboard might have quick function keys. The bottom of the keyboard has (fn) and another key on the keyboard will have the touchscreen icon.
Apr 10, 2014 | Lenovo Flex 15D 2-in-1 15.6" Touch-Screen...
Touch screen will not work on laptop
Check all drivers are loaded for the touchscreen interface, if they are remove them and re-install.
If that doesn't solve your issue I would check the cable that connects the touchscreen and that the touchscreen is fitted correctly.
Mar 19, 2014 | HP HEWLETT-PACKARD ENVY TouchSmart...
you can save all your personal data and re-install the O.S. again, or try to go to the computer properties and check if the touch screen drivers are there , if not you need to install it.
Nov 24, 2013 | Acer Aspire Z5600 PC Desktop
Touchscreen on a Garmin nuvi 1350 doesn't work. How do I fix this.
Try recalibrating it using the following method:
Nuvi 11xx, 12xx, 13xx, 14xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen. Press all of the prompted dots.
Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective and may need to be replaced.
Please see this page for additional information:
http://www.sharc.net/gps_LCD_repair.htm
Mar 29, 2013 | Garmin nuvi GPS
Touchscreen driver
You need to find out what Co. made the touchscreen for that model to see if they have updated touchscreen drivers for windows 8.
Sounds like your machine was intended for XP,
Feb 10, 2013 | Tablets & eReaders
My touchscreen is not working after i instal windows 7
Hi.
Based on the information you have provided, it seems that the issue is due to the Driver for the Touchscreen sensors.
As you have changed the Operating System, it is required to install the Touchscreen Device Driver for the Windows 7 Operating System.
Once the Driver is installed, the Touchscreen Device should work normally.
Please let me know the exact Model # of the Computer, so that I can provide you the link to download the Touchscreen Driver.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 23, 2010 | Computers & Internet
I have a HP Pavilion tx2620es with Windows Vista 32bits working perfectly, i buy Windows7 Upgrade Kit from HP, so i installed it and all sort of problems became: -Rotation of screen has stop working -Touch...
TRY TO DO CUSTOM/CLEAN INSTALL OF WINDOWS 7, BUT BEFORE INSTALLING IT DOWNLOAD WINDOWS 7 upgrade advisor , HERE IS THE LINK http://www.microsoft.com/downloads/details.aspx?FamilyID=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en RUN IT ON VISTA TO MAKE SURE WINDOWS 7 IS ABLE TO BE INSTALLED ON YOUR PC. BECAUSE WINDOWS 7 IS NEW OS IT MIGHT GIVE YOU MORE TROUBLES ON TABLET PC`s, MICROSOFT STILL UPDATING THEIR DATABASE FOR CORRECT DRIVERS FOR WINDOWS 7, ANYWAYS , I`LL SUGGEST YOU RUNING UPGRADE ADVISOR ON VISTA.
Mar 09, 2010 | HP Pavilion Tablet Notebook
My Toughbook CF-18's touchscreen stopped working. Do I need a driver? If so, can someone send me one? KitCopemma@gmail.com
Download the touchscreen driver from the Panasonic site.
Go to Start > Control Panel > System
Click the hardware tab.
Click the device manager tab.
In device manager click on Mice and other poiting devices
Select the touchscreen with left click and click the unistall option.
Once done close all windows and install again using the downloaded file from Panasonic.
Feb 02, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Acer Aspire Z5600 PC Desktop Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
