Hi my samsung HOYT6YK wont scroll on the key pads or the touch pad for some reason? also it wont select anything on the touch pad? cursor is still working though, can you help please?
frenzy19
  • 258 Answers
SOURCE: touch pad
your touch pad might be disabled find the fn key + touchpad icon usually found between F1 to F10 the icon is like a square with pointer above it
Posted on Nov 20, 2008
Murphybanton
  • 2004 Answers
SOURCE: HP Pavilion dv8000 - touch scroll pad won't work
at the top black rim around the touch pad, there is an orange light showing, press and have it show blue. It will work now.
Cheers.
Please rate this fixya.
Posted on Apr 10, 2009
MPetro302
  • 298 Answers
SOURCE: my compaq laptop touch pad scroll vertical zone
unless someone with that specific model or similar can answer your post I would consider calling HP's support phone number. Im sure they can assist you or find out if its faulty and get you a replacement.
Posted on Apr 20, 2009
SOURCE: Samsung R519 Scroll not working?
Try the Samsung System Recovery Solution. It worked for me. Use the basic restore. It doesn't delete any of your user files, but only restores healthy windows setting.
Posted on Feb 16, 2010
tech-hero
  • 66 Answers
SOURCE: i bought acer aspire 4738z recently. the scroll in
try installing synaptics touchpad driver included in the CD drivers.
Posted on Dec 14, 2010
How do I fix my acer aspire touch pad?
some touch pads have a tap to turn off, and a double tap to turn back on... also check you F keys.
Jun 03, 2014 | Acer Aspire Computers & Internet
Touch pad scroll is not working
The reason why your cursor is jumping all over the screen is because you are touching it by mistake with your thumb or hand somehow. You can turn the sensitivity down ans set two finger scroll (and other options) for your touchpad - go to control panel > mouse > device settings >
If you do not have device settings, you need to download the official drivers and software to enable all features. The driver you have is probably the default win 8 generic one. Let me know the model number of your laptop and I can help.
Nov 05, 2012 | Asus Notebooks R500A-RS51 Laptop
After using for sometime, scroll pad not working well. Cursor stops at any place, vibrating without touching the pad and become impossible to move the cursor in all directions. Then PC has to be shut down...
First Try doing the same in the safemode
Start the Computer with Press F8 key (keep on hitting it before window screen appear)
It will show you the windows advance option
Select the safemode with networking and enter
Login to the user account
Check the Scroll pad if its working fine then there is some problems with software - need update
Jan 08, 2010 | HP Compaq 6730s Notebook
Cursor moves, wont click!!
i think there may be two reason.1/some setting may be worang-go on conttrol panel and chose printer and other hardwere. inside click mouse and look setting.2/ your touchpad driver may not be working properly. stall it next.
Jun 11, 2009 | Toshiba Satellite A105 Notebook
Whilst typing the cursor moves to another part of the document
If your laptop has the option too you can turn off touch pad through a switch above the touch pad.
If you can't find this, or you don't have one, simply go to the run command and type in devmgmt.msc, ok.
Once in the device manager go "Mice and Other Pointing Devices"
look for your touchpad, right click on it and select disable.
Please note, some laptops wont let you disable to the touchpad, mine wont, but mine has an on and off key.
ON/OFF Key
Touch Pad On
Touch Pad Off
This will keep the mouse from moving whole you type, but I suggest you get a regular mouse, especially if you have to disable the device with the Device manager.
Jan 05, 2009 | Computers & Internet
Touch pad
Nov 20, 2008 | Computers & Internet
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Cursor Will Not Stay Put
Try uninstalling the drivers from the device manager, then do a hardware search. It will automatically find the touch pad and reinstall the drivers. If this doesn't work, then check the connector under the keyboard. Disconnect it and reconnect it, they sometimes work loose. If these don't correct the problem, then you have a faulty touch pad and you'll have to replace it.
Jun 20, 2008 | Toshiba Satellite A45-S250 Notebook
Cursor skips lines while typing
My experience: cursor suddenly moving backward when i was typing, or moving somewhere else on the page. I would be typing and text suddenly would get highlighted. I followed someone's advice to disable the touch pad. Since I do have a mouse & key pad that was all i had to do.
HOW TO DISABLE THE TOUCHPAD FOR ACER 3680 AND OTHERS??? PRESS Fn +F7
Yep, it was that simple. At first I made sure i typed without my fingers or palms touching or near the touchpad. I noticed it seemed to stop or happen less. Soon as I disabled the touch pad all is back to normal. Yet I spent hrs trying to find out how and there were all these posts by people suggesting downloads and other more complicated things etc..
May 12, 2007 | Acer NSK8458AN Keyboard
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
