Question about Jml Ceracraft 10" Ceramic Frying Pan
How do I seal my pan
My pan does stick what can I do
  • 23 Answers
Follow the directions that came with the fry pan to re-season it.
Posted on Feb 09, 2015
How do I remove the oil pan on a 1999 chevy van 4.3
if the pan has never been off then manufacturers use an adhesive sealant to stick the pan on.
Be sure that ever bolt has been removed ( bolts at the main bearing caps at either end)
take a sharp object (old wood chisel) and a hammer and gently break the seal between the pan and the crankcase. work along the edge gently so as not to deform the edge of the pan.
Feb 12, 2015 | Cars & Trucks
Transmission leak in pan but it's not the gastet, pan or seals
does it have a dip stick ? i had same thing on a chrysler 180 and was the o ring seal for the transmission oil dip stick
Mar 26, 2014 | 2007 Mercury Mariner Premier 4WD
Leaking oil Ford Freestar-was halfway between two lines on dipstick when I checked last week-puddle this evening and am down just past the bottom line-put in a quart but am worried to drive the car to
well it could be several things like pan plug seal cracked, oil pan leaking, rear main seal bad, front engine seal bad, head bolts not properly torqued, head could be cracked, but I would start with the oil pan drain plug seal and work from there.
Jan 03, 2012 | 2006 Ford Freestar
What is the main cause of a transmission leak on a 2001 v6 silverado?
front seal or pan gasket look and see where it come from 9106545823 if you need help
Feb 08, 2011 | 1999 Chevrolet K1500
I am trying to find my dip tick on a 2000 Izusu trooper 3.5 I have look under the hood of my Izusu trooper, near the oil dip stick, on the other side of the engine, towards the back passages side toward...
what kind of dip stick??? Transmission. No dip stick as tranny is a sealed system. U cannot add any fluid or check levels. U need a special machine to pump it in. Well....actually I jimmy rigged a hand pump to refill mine after I acidentally drained it thinking I had found the oil pan! Believe it or not I am not the only one who has pulled off that ******** move.
Nov 28, 2010 | 2000 Isuzu Trooper
Need new oil pan does it come right out or off
As long as you have all the bolts removed that hold the pan to the bottom of the block. Just make sure you drained all the oil and when you have all the bolts off, lightly tap the oil pan with a rubber mallet to break the seal that makes it stick to the block. If you need to use it, use a puddy knife to break the seal if the mallet isn't working. Just remember to scrap away pieces of the seal that stayed on the block or oil pan before putting the new seal on. It will save you heartache in the long run. Hope this helps.
Sep 13, 2010 | 2002 Jeep Grand Cherokee
Just bought a 1993 sl2 saturn and it is leaking trainy fluid. What could be the cause
The front seal,rear seal,pan gasket,transmission cooler lines,the kickdown cable has a seal, speedo sensor has a seal,solienoid pack has a seal,dip stick tube, plus it could be way over filled. the most costly will be the front seal at a shop
Jun 15, 2010 | Cars & Trucks
How do you remove the oil pan from a 1990 Dodge Caravan SE?
FIRST OF ALL REMOVE NEGATIVE BATTERY CABLE.REMOVE OIL DIP STICK.RAISE THE VAN SUPPORT IT USING JACKSTANDS.MAKE SURE YOU ARE ON HARD LEVEL GROUND.ALSO USE PROPS TO BACK WHEELS LIKE A LARGE PIECE SPLIT WOOD.THAT KEEP VAN FROM ROLLING BACKWARD WHEN YOU JACK IT UP.ALSO APPLY EMERGENCY BRAKES.NOW WITH VAN UP AND SECURE.DRAIN OUT ENGINE OIL.REMOVE ENGINE TO TRANSAXLE STRUTS IF EQUIPPED.REMOVE THE TORQUE CONVERTER OR CLUTCH INSPECTION COVER.REMOVE OIL PAN RETAINING SCREWS.AND REMOVE OIL PAN AND SIDE SEALS REMOVE ALL OLD GASKET FROM OIL PAN.CLEAN OIL PAN GASKET SURFACE AND CLEAN ENGINE SURFACE WHERE GASKET MEET.USE PAPER TOWELS AND ACETONE CLEANER IT WILL REMOVE OIL.YOU CAN USE BRAKES PARTS CLEANER ON OIL PAN.IT WILL REMOVE OIL QUICKLY.WHEN EVERYTHING IS CLEAN AND DRY.NOW APPLY SILICONE SEALER TO THE 4 ENDS SEAL TO BLOCK CORNERS AND INSTALL THE END SEALS MAKING SURE THE CORNERS ARE NOT TWISTED.THEN APPLY SILICONE TO THE 4 PAN TO BLOCK CORNERS.INSTALL A NEW PAN GASKET.INSTALL RETAINING SCREWS AND TORQUE THEM TO 17 FT LBS.WHEN YOU PUT EVERYTHING BACK IN PLACE DONT FORGET TO PUT OIL BACK IN ENGINE BEFORE CRANKING IT UP.WHEN CRANKING ENGINE UP GETTING IT RUNNING CHECK FOR OIL LEAKS.
Apr 18, 2010 | 1990 Dodge Caravan
Hitachi HB C103 bread machine pan seal
The problem isn't the seal, it is the bearing. You need to disassemble it, clean it, and lubricate it. Turn the pan upside down, and there's a C-ring that you need to pry off. Then you can tap the shaft through the bearing, and it will fall out. Clean the shaft and inside of the bearing, lubricate it, and reassemble.
I usually lubricate with vegetable oil, to avoid any chance of noxious contamination getting into the bread, but I've read a recommendation to use liquid graphite lock lubricant, available from NAPA Auto Parts, to prevent the bearing from sticking again as soon:
http://reviews.ebay.com/How-to-lubricate-your-bread-machine-pan-shaft-bearing_W0QQugidZ10000000016577277
BTW, be careful of that rubber seal -- they are apparently irreplaceable! (I need one, if you find a source.)
-Dave
http://www.burtonsys.com/email/
Oct 28, 2009 | Kitchen Appliances - Others
TRANSMISSION OIL LEAK
Hi, if there is no dip stick, the transmission may be sealed. in this case, your issue will be a main seal or faulty transmission pane seal(gasket). if possible, raise your vehicle so that you can get a good look at the pan and main seal area..
May 20, 2009 | 1998 Volkswagen Jetta
Jml Ceracraft 10" Ceramic Frying Pan Logo
1,161 people viewed this question
Top Jml Home Experts
Donni Steen
Tom Chichester
Are you a Jml Home Expert? Answer questions, earn points and help others
