Question about Samsung Washing Machines
Unethical Trade practice of a retailer of samsung washing mach
Dear Sir,
I have purchased a samsung washing machine (Front Loading, fully automatic, allegedly containing Ceramic Heater.) from M/s Shubham, Samsung Plaza, No.70,G.S.T.Road, Chrompet, Chennai-44. During the negotations, I was told about a model Wf R1061EW which contains Ceramic Heater. I was charged Rs.2,500 extra for that additional feature.The bill was also made, mentioning WF R1061 EW. But, when the piece was delivered to my home I was shocked to see the model is entirely a different one.(WF R1061 W1/XTL). Immediately I contacted the dealer and I was repeatedly told that both the models are one and the same. Not convinced, I have contacted the Samsung Support Centre over phone and I explained the whole thing. I was given a reference number(8405331169) and was told that the model delivered to my home does not contain any Ceramic Heater. Now, again I contacted the Dealer and the dealer says the delivered model contains the Ceramic Heater. Without using the machine, I am keeping it for further developments. Under these circumstances, please guide me. I very much feel cheated by the dealer. Expecting a reply fromyou.
Thanking You,
R.Ramalingam
  • prem mathew May 11, 2010
    Best is you contact a consumer redressal forum, they will guide you about how to deal with this, you can mention how you were cheated, etc. Then notice will have to sent to the dealer, with copy to manufacturer.
  • 120 Answers
SOURCE: no owner's manual with new product
If you go on the manufactures website. You will be able to get an manual sent to you.
Posted on Jul 07, 2009
beltronic205
  • 1474 Answers
SOURCE: LG Washing Machine front loading, Model Fuzzy Logic 8.5KG,
If it has a belt remove this then turn drum by hand to see if noise is still present if it is then sounds like some thing caught in between drun inner and outer you may need engineer....Pull plug out 1st...
Posted on Mar 22, 2010
  • 113 Answers
SOURCE: Hi Unable to drain the water
You can take the hose that goes to the drain and lay it down. but when you do that the water will run out the hose so make sure it goes outside or into a floor drain. You pump is either jammed or broken or the solenoid that turns it on is out.
Posted on Sep 22, 2010
SOURCE: My Samsung Washing Machine (Diamond Drum model) problem
You probably did not save the mode you want. See the information booklet provided on how to set the mode.
Posted on Oct 29, 2010
  • 6277 Answers
SOURCE: error 5e will not empty
Samsung '5e' means 'water drain error'.
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 10, 2011
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Drain prblem
I used to get this problem with my Samsung,only the impellor was loose and needed refixed to the shaft.Sounds like the capacator that gives the pump motor it's initial kick start is gone so the pump can't start to turn until you help it,then,I assume,it will keep going.
Depending on the design of the pump,it could have a built in or separate capacitor,so you'll have to establish which it is before buying either a capacator or pump assembly.
Jul 04, 2012 | Washing Machines
Dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
Dec 08, 2010 | Samsung Washing Machines
Hi Unable to drain the water from my fully automatic top loading samsung washing maching. (Model - WA80TAL). How to do it. Regards Uday Sundar
Sep 22, 2010 | Samsung Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
