Question about Kenmore Dryers
Kenmore 66002 squealing - Kenmore Dryers
My dryer is squealing and won't spin
It sounds like the drum is frozen. The squealing is from the motor slipping on the belt. There may also be something keeping the belt from tightning. Try these links:
ShopYourWay
Appliance411 Home Service Appliance Repair Manual for Whirlpool Kenmore...
User Manual Downloads
Feb 05, 2016 | Kenmore 73952 Gas Dryer
Squeals while drying clothescould this be a bad belt ?
It can come from two things, belt for sure when you over load the dryer or it is getting worn an second the rubber wheels the drum sets on can squeal.
Mar 29, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore solid state dryer. was squealing while running. now drum stops and starts. still squeals
belt, idler pulley, drum glide/rollers:
belt/idler pulley:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
rollers/glides:
http://www.partselect.com/dryer+replace-glides+repair.htm
belt configuration
http://www.applianceaid.com/images/belt-config.JPG
Dec 03, 2010 | Kenmore Dryers
Loud squealing sound when the basket first spins up this is a Kenmore stacked set, washer on the bottom, and dryer on top
Your problem could be a bad bearing...The drum rides in a bearing at the rear middle of unit..Its basically a plastic insert...When the dryer is first started the bearing will squeal until the plastic warms up..Normally you will hear the squeal at the back middle of dryer...Your problem may also be the belt tensioner...Again a plastic wheel with a metal bearing inside...Normally this squeal will be from start to finish..
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
During washing the kenmore 70 series washer squeals
Re-check the motor coupler.
If it was not seated flush on both post it will bind and squeal.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 dryer gas model 76712693-76712 squealing
Raise the top.
Remove the front panel.
Remove the drum.
Remove and replace the drum rollers and the belt tension roller.
Jan 20, 2009 | Kenmore 72982 Gas Dryer
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Jan 19, 2009 | Kenmore 63942 Dryer
Dryer really squeals
Ok this is a really broad question, Kenmore will squeal when a belt tensioner or motor bearing is out, a frigidaire or small kenmore with control panel above the door and serial number starting with x will squeal when the bearing is out on the drum or the motor. This is a general cover on dryer noise with a model like Kenmore series 80 I can give solutions ok?
Sep 20, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
