Question about Garden
Mower deck stays engaged all the time - Garden
  • Jerry Cramer May 11, 2010
    do you have oem belt on your tractor ?
  • 86 Answers
Does your mower have a electric clutch ? If so it could be bad,If not do you have the right belt from the company the mower was made by ? If its the right belt then your brake for your blades is bad.
Posted on May 12, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
I have a MTD yardman 1999,2000 ride mower that won't start because it says the pto is engaged when it's not actually engaged if you could comment an image of the same 42 inch deck?
Check your PTO switch operation which is at the engagement handle.
As for hooking the cable spring to deck idler pulley and brake assembly it goes in the hole closest to the idler pulley on the G deck which different then the F deck which uses the same idler arm assembly as the part is design to fit both decks.
Also make sure your using an OEM spec as a will fit will not work properly. You also must the spindle pulleys belt retainer covers in place so the belt will stay on.
May 10, 2015 | Mtd Garden
Blades to disengage
On mower deck there is a pulley that engages the belt to turn blades. Find it, While tractor is shut off check that spring is on the bracket that moves pulley back when disengaged.If gone replace it. If its there, slide bracket back and forth to find out what it is catching on.
Jun 24, 2014 | Mtd Garden
Why does a craftsman tracor with a kohler 15.5 hp engine bogg down when engaging blades
It will initially bog down when engaging, but should pick back up shortly after. If it is staying bogged down, turn mower off and check inside (under) the deck to make sure its not clogged up with grass clippings or dirt. if it is, clean it with either a hose or a scraper. Also make sure the deck is raised when you engage (dont engage with deck lowered on long grass).
Jun 15, 2014 | Craftsman Garden
I have a Cub Cadet 2135 mower deck issue: Started OCCASIONALLY shutting off on turns and down slopes. Turned the switch off then on and it worked until another seemingly random time as above. Now, deck...
repair the seat first remove seat and reinforce metal use metal plate on top and washers on bottom or reverse make sure seat is secure so that u do not loose the ground contact on safety switch their is also a safety switch on shifter lever and brake pedal check them for rust and a tight contact
Nov 02, 2013 | Garden
My blades stay engaged at all times model # 917273012
if the blades are staying engaged all the time try and unplug the switch if they still stay on you have a short also try getting off the seat that should shut them off as well shifting into reverse should shut them off as well if they stay on threw all that you have a shorted wire in the system
Jul 09, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
EXmark mower blows fuse when deck is engaged.
try checking the wires from the switch that engages the mower deck. if there is a wire grounding out sumplace when you kick it on it will keep popping the fuse no matter what. id say its a short.
Mar 16, 2012 | Craftsman Garden
Lawn mower stays running on jumper cables but once disconnected it shuts down when choke is engaged
if it is already running and you "engage" the choke, you will flood the engine with too much gas and it will sputter and die. the only time you engage the choke is to start the engine when it is cold. if the mower dies when you remove jumper cables, and you leave the choke alone, you need to have someone look at your charging system.
Apr 08, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
183 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
