The power keeps shutting off when I turn the volume up.
Any time i apply volume to the system and try to push the amp the power shuts off. Its not loud but it still shuts off. What do I do?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Check the nomimal ohms or impendance of the speakers if it matches the amp capability. Your amp manual should specify the compatibility of what speakers ideal to whether it's 4 to 8 ohms.
Posted on May 08, 2009
Kenwood kdc-mp142 why does it shut down when
Have you checked your speaker wiring as it could be you have some wires crossed ie: negative feeding the positive side causing the shut down & check the Ohms if at high volume you are trying to drag to many Ohms it will also cause the built in amp to shut down to protect the system dont keep incresing the volume as the strain will do damage
Sep 18, 2014 | Car Audio & Video
Reciever shuts off after turning the volume up
You will have to change the volume controller and its circuit board.
F150 Accessories
Aug 12, 2012 | Audio Players & Recorders
My alpine keeps shutting down when the volume is turned up past 20. Plus I have no sound coming out of my subs. I tried switching rca cables. And I sent my amp off thinking it was my amp. Their is a little...
so it turns off suddenly and then the next second it turns back on and starts playing
from that and personal expericance i belive that the radio system (radio and amp) is not reciving enough power
is this radio inside a car
if so what car
what i would do is attach bigger thicker wires to the positive and negative of the amplifier
direct from battery
positive of battery>>>> positive of amp
metal grounding point on car>>>>>> negative of amp
(do not use negative of battery use the metal of the car)
May 12, 2010 | Car Audio & Video
Receiver shuts off at higher volumes
The receiver may be too under powered for your speakers or the speaker ohm's may not be matched for your amp.
The reason it is shutting off is likely because the amp is becoming overloaded. At lower volumes the amp can handle the load of the speakers, but at higher volumes the power supply of the amp can't keep up with the power demand the speakers are pulling.
If you were previously able to turn the reciever high without turning off, then there is likley something wrong with the amp or possibly a blown speaker.
Try measuring the resistance of the speakers if you have access to a multimeter. They should normally read 8 ohms for home speakers, but some common home speaker impedances in order from (I'm assuming) most common to least common are are 8, 4, 2(bose), and sometimes 10 or 12 ohms. The lower the number of ohms, the more power the amp will need to put to the speakers and the more chance you could be overloading your amp.
Mar 30, 2010 | Audio Players & Recorders
It turns off with an error to Check Speaker wires. It's done this in the past, usual if I push the volume too it's threshold. It would always bounce back. Now it shuts down at just about it's mid-peak...
Did the fact that it was responding negatively to the loud volume not suggest it might be a bad idea to keep doing it?
The threshold on the volume knob is NOT where normal undistorted listening levels are found. Given a normal level of input you could be pushing your amp so hard that it clips or distorts and kills your speakers.
Do what it asks: check the speaker wires for shorts. Or disconnect the speakers and pray it comes back to life, then isolate the shorted (dead) speaker.
Feb 23, 2010 | Yamaha RX-V657 Receiver
Rockford fosgate amp keeps shutting down when volume is cranked
your cd player cant handle all the power, time to upgrade to a cd player with at least 80w10
Jun 12, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Gemsound power amplifier exa3955 keeps shutting off.
it is most likely that the shutting off is an precautionary system response to protect your amp and drivers. check all connections again for wrong polarity.
Feb 01, 2009 | Audio Players & Recorders
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Dec 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
KENWOOD VR-507 RECIEVER
No, take the battery out and bring it to an auto part store and they can test it.
Jun 18, 2008 | Kenwood VR-507 Receiver
Head Unit Shuts Off At a Certain Volume
check your ground, it could be that your antenna is the only source of ground, in which case the deck does not have enough power to stay on when it draws too much power. I've seen exactly what you are saying many many times. Ground it really reallly good.
May 10, 2007 | Alpine CDA-9853 CD Player
59 people viewed this question
 Grubhead
Grubhead
