Konica Minolta bizhub C250 All-In-One Laser Printer Logo
h
hassan Posted on Nov 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Photocopieuse minolta bizhub c5501 for code error c-3801
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Mar 11, 2018
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913566
Points
11960
Fuser is low temp. reset in service mode, if code comes back do not reset as this deals with fuser the hot part can catch on fire
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • Posted on Nov 19, 2007
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
firecontrol7
Norman Weimar
  • 7035 Answers
  • Posted on Jul 25, 2009
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Anonymous
  • Posted on Nov 03, 2009
SOURCE: Error code C-0211 Konica Minolta Bizhub C-351
I have a Konica bizhub c351 with and error code of c0211. I took the back off and played with the black motor that lifts the tray. The tray moves freely and the motor seems to move freely. When I turn the machine on it does not go through any kind of check like it did before it just goes to the same screen. Is there a way to reset this to get it going again to test if there is still a problem
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 17, 2010
SOURCE: C03FF Minolta bizhub 210
C03FF, is the improper or unmatched model setting code. go to "service mode" In service mode please select "ADJUST"
in "ADJUST" please select "Model Setting" in "Model Setting" select the cpm, (Copy speed) of your machine, for example if you have bizhub 210, then select "21" from the list. if you have bizhub 163 then select "16" from the list and press "yes" button. code will remove.
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Aug 07, 2010
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Konica minolta bizhub pro c5501 with error c4719 - what does it mean and what do I need to do?
Hello, this is related to Magenta write ulit/laser unit. Check connecters both to write unit and that of pcrb. Mostly this error come after removing and replacing the units. Otherwise replace the unit. Some time rewriting firmware clears the error but thos should be the final option.
1helpful
Bizhub pro c6501 c-2453 error code
cyan (blue) developer unit and or developer motor
Code d'erreur c-3804 sur photocopieuse minolta bizhub c5501
sir/mam
Konica Minolta Laser error c2424
whats the model number
Konica minolta c6501 error code c-2414
replace the black developer and or the black developer and black developer unit
After pring a job the mashine tells me to call for service center Report code C-C102 on Bizhub C5501
Printer control board has issues. Check all connections, firmware up date if possible or BAD BOARD
My Konika Minolta Bizhub 361 is coming up with a error code c-3801 what does this mean?
Replace the Fixing Sensor assembly (p/n 50GA -544 0).
Fusing main sensor low temperature abnormality. While in the idle or in the low power mode, the fusing heater lamp /1 (L2) turns on for more than 12 seconds in succession.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
