Question about Acer Aspire 5500 5570-2609 Laptop
I would like to transfer files from my laptop to phone
I would like to transfer files from my laptop to my phone using infrared or blue tooth..
Acer Aspire 5520-5290
LG VX8700
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    just switch on the bluetooth first thru button normally located on the left side or in the front panel marked Bluetooth ,it will light up blue color then see the small icon on the right corner of taksbar right click and Open bluetooth settings and then select options tab and then check the allow the bluetooth devices to find this computer check box and then come out selecting OK
    now try to send some file from phone or pda thru the sending option and then search the bluetooth devices in ur device u will see ur pc in the list just select do the pairing first use code 0 zero to pairup both devices put zero on both sides and then conection will be established now u can easily send data from both devices thru bluetooth
    pls let me know if it helps or u have some other problem of switching on the bluetooth device
Have a problem with infra red, it is enabled, but comes up with problem with infra red driver. is this hard ware, or soft ware
Posted on Aug 11, 2009
How to send music to a cellphone
You can transfer the music files to computer, and then use an android transfer software to add them to your another phone.
MobiKin Assistant for Android Windows Version
Jun 26, 2017 | Cell Phones
Do acer aspire one d257 have infrared
It hasn't. Unless you have a USB connector on your phone, you may have problems transfering.
Jan 04, 2014 | Acer Aspire One D257 Netbook
How to transfer photos from siemens cl75 to laptop
Use Ir Da (Infrared) function (old fashioned blue tooth) You might have this function on older computers otherwise you can get an Ir Da / Infrared dongle for about 10 pounds. You go to the photo, options, send and then 'send by IrDa'. You have to do it photo by photo and have phone near computer/dongle - but it worked for me.
Feb 24, 2012 | Siemens SL75 Cellular Phone
I want to transfer picutes from my phone to PC
Welcome, Thank You for giving fixya.com the opportunity to HELP!
Your issue:
I want to transfer my pictures? from my phone to my pc.
Solution:
Your case will need the following kit witch you can purchase from HERE
If you already have the USB transfer cable all you need to do then is download the software from that website, install it on your computer, this will sync all your photos to your pc without a hassle.
We only give you the facts that you need in order to get the solution done. You will need to purchase if you have not already the transfer cable and kit from the source given.
Your ratings are important to us. Please be considerate when passing through Fixya.com to leave feedback so we know how we are assisting our askers.
Best Regards,
Rulds2008
Jul 16, 2011 | Motorola Mobility V265
I JUST WANT TO KNOW IF MY aCER ASPIRE ONE D250 HAVE BLUE TOOTH
Go to start->Run there you type "fsquirt" this wil open the default bluetooth file transfer wizard (In windows only). Click on next and select send file and once you click browse, it wil tell you whether the blue tooth hardware is already installed in your system or not.. I hope this wil help you.
May 14, 2011 | Acer Aspire One PC Notebook
I cannot find my bluetooth on my asprie 5542 control panel or accessories to enable me send or recieve files.
This laptop features Bluetooth for wirelessly transferring files with devices such as mobile phones, or connecting a Bluetooth headset for chatting online.
It has blue tooth so maybe a driver is missing. Check Device manager for any errors.
Mar 28, 2011 | Acer Aspire 5542 Notebook
Problem in transfering file via bluetooth
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jun 17, 2010 | Sony Ericsson K750
My nokia 3600 photos
You can transfer it via USB data cable, just connect the cable into your cell phone and your pc, and transfer ( different cell phones have different ways to transfer ) so you have to be more speciefic about the brand and the model number of the cell phone.
Another way is through Bluetooth and infrared if your PC is supported to receive blue
tooth and infrared links. I prefer you to get your guide from your cell phones manual.
Thank you.
Aug 16, 2009 | Nokia 3600 slide Cellular Phone
My c261 problem
HI there,
  1. You have to set both unit blue tooth configuration settings.
  2. Turn On the blue tooth for each unit
  3. Make or initialize pairing on the unit that will send the data.
  4. The other end(cellphone) has to accept the connection invitation from your cellphone.
  5. It will ask a password, you can input a 1234 or just leave it blank if you don't want to use a passkey.
  6. After you have done the pairing, select the file you want to transfer.
  7. Select Option >> Send >> Via Blue tooth.
  8. Select the paired cellphone you connected via blue tooth that you have DO on steps 3.
Hope this initial info helps.
Just let me know for further instructions.
micro
Jul 19, 2009 | Motorola Mobility C261 Cellular Phone
Acer Aspire 5500 5570-2609 Laptop Logo
144 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
