Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Sony dcr-hc21 very odd problem with the lcd. if i open the lcd panel to the first position facing me it doesn't work but when i turn the panel to the other side it works. please help
  • 10,594 Answers
Connecting flexible cable between LCD and Camera board is cracked and requires replacement.
Let me know if you want to replace it yourself to provide you part number info for that flexible cable.
Posted on May 08, 2009
My Sony Handycam DCR-HC21 touch screen stopped working.
This is usually caused by a defective LCD module or a defective flex cable that connects the LCD to the camera. I recommend replacing them both at the same time. The LCD / Touchscreen module is no longer available from Sony for this Model. However, I have a limited supply of them in stock as well as an aftermarket supplier with hundreds of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Aug 21, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
Hi I have a sony handycam DCR-HC21 and sometimes the LCD screen is black so you can not see what you are filming. You can still record with the LCD door shut. Any ideas why it is not working?
It could be a lose ZIF/ ribbon cable. This happens alot with adjustable LCDs. You might be able to fix it by taking the LCD's back panel of and making sure the connections are secure. It also might be a bad switch, Does it transfer off the viewer when it's still open?
Feb 26, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Buttons on touch panel of my DCR-HC21e Sony Handycam stopped working.
This fault is often caused by a failing flat cable that connects the LCD panel and the rest of the camera. In its early stages it is possible to get the buttons on the touch panel to work by carefuly changing the angle of the LCD panel while trying out the buttons until you get a position where they work.
When the flat cable gets worse , the picture on the LCD panel will start deteriorating and go off altogether.
At this stage you may consider having the flat cable replaced.
Oct 01, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
LCD panel is black of my dcr hc21. I have to change the LCD panel for a new one? Whats the price of the LCD panel?
r u sure that ur lcd pannel damage most proberly goning that lsd fpc u just conform that first because that fpc is very cheap
Jul 07, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony handycam LCD problem
1-864-761-11(FP185)
Part no.of flexible cable of DCR=HC21
Jun 09, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
LCD Screen not working, no way to operate cam or set dates in the cam or view tapes, view finder lens works but can't play or set dates? there for camera is a paper weight???
There is flexible connecting wire between LCD board and main board of camcorder that is broken and requires replacement.
If you can apart camera and exchange that wire then let me know to provide you part number info of flexible wire for Sony DCR-HC21 Camcorder.
Mar 14, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
White LCD Screen on Sony Handycam DCR-HC21
check whether can see the picture through vew finder,if yes replace srtip wire from main board to lcd bord
Jan 10, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
215 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
