Question about K'nex Semi Truck
9400I battery hook up - K'nex Semi Truck
I'm getting no power to my gear box in my 2007 international 9400i automatic 18 wheeler
Hi there I am technical mechanical and electronic engineer mechanic have you check out the grounds all over from to back
Oct 25, 2015 | Cars & Trucks
I have a 2007 international 9400i cummings eng fuel is not leveling only drawing from 1 tank
check for blockage or damage to crossover tube ,or cap on tank vent clogged
Sep 30, 2014 | Cars & Trucks
I have a 2001 9400i internation back brake light won't come on
Check the no brainers first. Fuses, relays and bulbs. If that is not it then you need to get into grounding and wiring.
Aug 30, 2014 | Cars & Trucks
Need driver for phillips 9400i recorder
Instructions can be found here:
https://www.emdat.com/software/insync_recorderPhilips9400i.asp
Jan 24, 2014 | Televison & Video
2004 international 7400 heater fan works but can`t get air to defrost?
Where is a the heat actuator located on a 2004 International 9400i. I have heat thru vents only no defrost could like some advice.
Nov 01, 2011 | Cars & Trucks
No distance on cb
Check your antenna. Make sure it is getting a proper ground. If mag mount; make sure base of antenna and where you put it are both super clean. Check where whip goes into coil or base. Make sure all allen screws are tight and whip is not either all the way down to the base or up to the top. If antenna is mounted; make sure that it has a good ground. You might have to remove some paint around the base to get a good connection. DO NOT TRANSMIT WITH A HIGH SWR. YOU CAN BURN OUT THE EXPENSIVE POWER OUTPUT TRANSISTOR. Hope it helps.
Tom
Jun 07, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
K'nex Semi Truck Logo
50 people viewed this question
Top K'nex Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a K'nex Toy Expert? Answer questions, earn points and help others
