Question about Philips SRP4004 Remote Control
Can't change aspect ratio - Philips SRP4004 Remote Control
Aspect ratio selection
On your remote control there is a button that controls the aspect ratio on you television. Push the button to change the aspect until you get to the desired ratio.
May 21, 2014 | Polaroid 22" Class 1080p 60hz LED LCD HDTV...
Cannot change aspect ratio when im playing a game it cuts off part of the screen
Normal aspect ratio is 4:3, and the wide aspect ratio is 16:9. If you play a game meant for 4:3 and you change the TVs aspect ratio to 16:9; part of the picture will be cut off. It is not the fault of the TV.
Oct 15, 2010 | Sanyo DS27800 27" TV
Picture size doesn't fit the screen I tried to adjust the aspect ratio but the option is locked on the menu. What to do? (Olevia TV model lt42hvi
You cannot change aspect ratio when recieving HD signal. Try changing the cable box or satellite box format or aspect ratio.
Dec 30, 2009 | Televison & Video
Cannot change aspect ratio of picture when ratio button is pressed on remote. Batteries in remote are good. Everything else on remote works. Sony KP-57HW40
If you are connected to a HD cable or satellite box, the aspect ratio is set by that box. If it is set for 1080i 16:9 wide screen mode then your TV is locked at that ratio. This is good considering you have a Hi-Scan 1080i television in the Sony KP57HW40. Please take a moment to rate my answer. Thanks...
Nov 24, 2009 | Sony KP-57HW40 57" Rear Projection...
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
Ilo tv
You need to change the aspect ratio of the screen. The cable box remote has an aspect ratio button and the tv remote also has an aspect ratio button or picture size button. You are probably on a zoom aspect since its too big.
Nov 13, 2008 | iLO 3200 32 in. LCD Television
I cannot change aspect ratio
If you are trying to change the aspect ratio on the television make sure you are sending an HD signal Via Component cables. I am not aware of a way to get HD cable without a PC cable card or box, it could be that your television is not receiving the proper signal (analog, or composite) to switch the aspect ratio on your particular television.
Feb 24, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Philips SRP4004 Remote Control Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
