Question about Discovery Channel Measuring Tools & Sensors
Weathertech TX2000 Outdoor Reading does not work
The batteries are good, but the outdoor reading on our Weathertech TX2000 does not work - just shows 2 dash lines
    Novelist:
  • 235 Answers
I hope you also know the transmitter is not weather proof. I know that is not logical, but it is a fact. I wrapped mine in plastic and left the bottom open to reduce condensation. I hung it at the northern end of my home out of direct sunlight. Archery tech is correct about putting it close to the base to set it. Poor technology I guess.
Posted on Sep 27, 2014
5 Suggested Answers
SOURCE: i put new batteries into both units, the indoor
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Posted on Oct 18, 2010
SOURCE: My Nexxtech wireless weather station
You must move the remote sensor close to the base unit to reset it and it will work fine. After it shows the temp then you can move it back to its location. thanks for asking at Fixya.com.
Posted on Dec 02, 2010
SOURCE: I have the Acurite 00604RX
how do i set my clock for accurite 00604RX
Posted on Sep 07, 2011
  • 22 Answers
SOURCE: i have this model and the outdoor temp sensor isnt
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Posted on Nov 30, 2011
Changed batteries and now cannot get an outdoor reading.how do I fix this?
  • Remove all batteries
  • Install batteries in outdoor unit
  • Make your way indoors at a leisurely pace. This allows the outdoor unit to initialize and begin sending data
  • Install batteries in indoor unit. You should see outdoor temperature displayed
In cold weather, the outdoor temperature display may disappear due to frozen batteries. At the moment my reading is - - because it is around 40 deg. F. However, in a day or two when the outdoor temperature reaches 50 deg., the outdoor temperature will be displayed again. All in all, rather whimsical.
Jan 22, 2017 | Measuring Tools & Sensors
I put new batteries in Transmitter and never got any temp reading.The unit is less than 2 years old and is not working. Is there anything I can do?
  • Install new batteries in transmitter
  • Wait for transmitter to initialize and begin transmitting temperature data
  • Install known-good batteries in receiver
  • Observe outdoor temperature reading
If this doesn't work, the transmitter or receiver or both may be defective. I find in very cold weather the transmitter stops sending the temperature.
Dec 08, 2016 | Measuring Tools & Sensors
Why isn't outdoor temperature displayed?
Try repeating the initial set up procedure. Remove all batteries from outdoor and indoor units. Install known-good batteries in the outdoor unit. Allow time for the outdoor unit to begin transmitting data. Install known-good batteries in the indoor unit. You should see the outdoor temperature displayed.
Feb 09, 2016 | AcuRite Acu-Rite 00621 Wireless Weather...
Outdoor temperature reading shows -40 with wind chill -62. Outdoor temp is in fact +45.
We would recommend a hard reset of your Weather Station. Please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac, and then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall battery into the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Mar 17, 2015 | Chaney Measuring Tools & Sensors
Can't get a temperature reading on my Springfield 91756 thermometer even after changing batteries. Just get - - -.
The batteries in the outdoor unit have to be changed first and time allowed for it to begin transmitting. If you are in a very cold location, the batteries may may decline in efficiency to a point where the outdoor unit can't transmit. In this case, you may find that the temperature reading returns in warmer weather.
Feb 23, 2015 | Springfield 91751 Digital Rf Weather...
Why does my outdoor temperature show a constant 35F?
It might not be in range I wouls try bringing them closer together or bring your outdoor sensors inside untill yoh get a reading
Dec 21, 2014 | Measuring Tools & Sensors
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
Can't reset Taylor 5367 indoor/outdoor thermom
I changed the batteries on mine and it reset itself. That was easy.
Dec 09, 2009 | Kitchen Appliances - Others
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Measuring Tools & Sensors Logo
432 people viewed this question
Top Discovery Channel Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Discovery Channel Measuring Tool and Sensor Expert? Answer questions, earn points and help others
