Question about Bose Wave Music System Remote
I have a 1999 Nissan Maxima with a Bose system. All of a sudden, the radio starts cutting on and off automatically. We are unable to manually power off the system or change any of the stations. I replaced the main audio fuses but this hasn't solved the problem. Is there a reset button on these systems? Does anyone know of the exact fuse that needs to be replaced?
sapperj
  • 70 Answers
SOURCE: Turning Off Irregularily
A voltage converter is not neccessarily the proper piece of equipment to use as most equpment comes with a 120/230 voltage selector. What is probably causing your problem is power frquency. Power in India runs on 50HZ, not the 60Hz we use in the states. This causes a slightly longer peak wave and can cause over heating, therefore shutdown. Check to see if the unit has a 50/60 switch and switch to accordingly.
Back when I was a professional sound engineer and toured abroad, we used a device called an auto-former. These changed the frequency and voltage as needed. Unfortunately the first time I went to England I forgot about this, could not find any pre-built ones and had to spend nearly a week designing and fabricating 8 of them....
Posted on Jan 01, 2008
SOURCE: replace fuse Bose Wave Radio
For the AWR1-1W turn it over and there are 4 screws that you must remove. When your looking at the circuit board the fuse is just below the power supply and back of radio. If the radio makes a ‘POP’ sound when you unplug it may not be the fuse as power is getting past the fuse. I have the same trouble with mine. I called BOSE Tech and he said if it makes that ‘POP’ sound after unplugging it is not fuse or power supply. They will not even allow me to send it in for repairs as the radio is over 15 years old and considered unserviceable.
Maybe someone else can give us a quick fix.
Posted on May 06, 2008
SOURCE: in line fuse
I have the same problem. To get to the circuit board remove all the screws from the bottom of the Wave radio. At least that is what we did, but ours is a really old model. There are two screws if you are looking from the back to the front on the front right corner that secures the bottom to the interior chassis THROUGH the circuit board. Careful! if you unplug all the gang connectors and those two screws are out it will come apart. My question is Where is this blown fuse located on the circuit board? I have two glass fuses in fuse holders that are ok.
Posted on May 22, 2008
dunnbiker
  • 8546 Answers
SOURCE: how to start a Bose acoustimass 9 powered subwoofer
The Bose cube systems are SYTEMS for a very good reason. They're made for people who want good sound but don't want to manipulate the hardware much. The speakers and amps are designed for each other ONLY, not only electrically but through soundshaping to provide the smooth final result. The design is for you to feed the electronics a Line Level source and the magic and distribution happens internally. These are NOT mix 'n' match components. The special connectors are a clue. The 'different' amplifier will probably blow them up.
Posted on Dec 28, 2009
neutronrace
  • 66 Answers
SOURCE: I have the bose 123 system. Where does the power
the acoustimas box has a power cable.
their is a cable from the acousimas (subwoofer) to the dvd plaver, the power supply is included in this cable
otherwise check site http://www.bose.com/pdf/customer_service/owners/og_321_2.pdf
Posted on Feb 15, 2010
I have a 1996 Nissan Maxima with a factory Bose CD player / cassette and radio and it will not turn on what's the solution
Maxima Bose Radio ' eBay
www.ebay.com/bhp/maxima-bose-radio
eBay1995 1996 1999 Nissan Maxima Pathfinder Infiniti J30 Radio BOSE CD tape Player ...Will fit and work in these with BOSE audio package only:1995 - 1999 NISSAN .... 2006Nissan Maxima OEM Bose Cassette & 6 Disc CD Player Radio CR13B ...DESCRIPTION Unit is missing some bottons, 3 of them, this item has NOT ...
Nissan Maxima Bose Stereo ' eBay
www.ebay.com/bhp/nissan-maxima-bose-stereo
eBayWill fit and work in these with BOSE audio package only:1995 - 1999 ... 1996 - 2000 NISSAN Pathfinder. 2004 2005 2006 NISSAN MAXIMA FACTORY BOSE STEREO 6 DISC ... Factory NISSAN INFINITI BOSE Radio, Tape, and CD Player. ... 6 Disc AM FM Stereo Cassette Radio Bose OEM LKQ (Fits: Nissan Maxima).
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair .... I have nissan maximal 05..the CD part turns on but the cd won't eject...should ... I have a 2005maxima non-bose radio system. ... my speakers is super in my 05 maxima but my cd player keeps on ...
Nissan - Factory Car Stereo Repair
Feb 03, 2016 | Nissan Cars & Trucks
2002 nissan maxima bose amp
it could be the amp , have your checked all your fuses .
Jul 18, 2013 | 2002 Nissan Maxima
I bought a sony deck to replace the bose stock deck on my 1996 nissan maxima. I purchased the wiring harness and antena adapter also. I hooked everything up right and getting power but im not getting no...
each speaker in your car runs the wiring thru an amp. So each spkear has its own amp for the bose system. You can not hook up a none bose radio If you do you will need to run new wires and replace all the speakers. Sorry.
Jul 02, 2011 | 1996 Nissan Maxima
My 1996 nissan maxima bose system resets its self
you need to pull the radio out and verify that you have 12 volts all the time at the Pink/Blue wire in the radio connector plug, this is the keep alive memory, without this constant 12 volts the radio will reset every time the key is turned off. I assume you have checked the fuses. If the wire is ok and has 12 volts present then the radio is defective and will need to be sent out for repair..
Apr 12, 2009 | 1996 Nissan Maxima
I hooked up a new radio in my 96 nissan maxima and get no sound.
Hook up the Amp Turn on Wire usually blue/white strip
Feb 21, 2009 | 1996 Nissan Maxima
1996 Nissan Maxima Bose Radio has no power
This
sounds funny but disconnecr the battery and then hook it back up-I did this and power was restored to my radio-I have no idea why this worked.
Good luck!!!!!!!!!
Dec 22, 2008 | 1996 Nissan Maxima
Radio is not getting power
you need a new radio unit. common with this car.
May 17, 2008 | 1996 Nissan Maxima
Bose Wave Music System Remote Logo
169 people viewed this question
Top Bose Televison & Video Experts
George Scott
George Scott
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
