Question about Magic Bullet Nutribullet Blender
Nutri Bullet does not start
Plugged in and all components appear in good working order. Depressing down on the blender attachment is diffucult. and does not engage the motor.
I went to plug in my bullet and it won't turn on.
There's 3 tabs on the inside of the base that get pushed down when you push the cup in. Two of them have switches on them, sometimes they can break. Make sure they are being pushed down. If not, it could be one of the switches inside.
Apr 09, 2015 | Magic Bullet Nutribullet Blender
How do i repair my nutibullet .I have power but the blades on both extractors are not working . It gives out a loud vibrating buzzing sound when pulsing .last blast i did was watermelon and it worked...
Do not try repair it manually,as its a concern of electronic gadget,& its hazardous.Get it done from a service agent or instead prefer ton buy a new one.I would suggest Magic bullet blender nbr1201.The Magic Bullet consumes less power than Magic Nutri Bullet when you compare Nutribullet Vs Magic Bullet, but it is more when it comes to the price factor. Though it is not that powerful, you can get Magic Bullet at much cheaper price than Magic Nutri Bullet.Go to the link to know.
Nutribullet And Magic Bullet Difference
Feb 23, 2015 | Magic Bullet Nutribullet Blender
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Sep 11, 2014 | Magic Bullet Nutribullet Blender
Won't spin when I push down
Maybe you'd find your answer a little quicker if you posted your question somewhere besides the refrigerator forum.
Feb 04, 2014 | Magic Bullet Nutribullet Blender
Bullet express manual
On search bar type: express bullet manuel. I was just on that web page. Tells anything you want to know about the Express bullet.
Oct 29, 2012 | Emson Magic Bullet Express Blender
I need an owners manual for the Magic Bullet Express.
for the instruction manual go to this link http://www.ehow.com/how_5691886_use-magic-bullet-express-blender.html
May 09, 2011 | Emson Magic Bullet Express Blender
My magic bullet express blender just stopped working while i was grinding soaked rice . will it work after a few hours when the motor cools down?
Most probaqbly not wet rice is possssibly too heavy for this littel motor to handle. The instryuctions say short bursts of grinbding. If the motor overheated it is possible the winding are now burnt and the unit is not repairable.
These cost 29,99 total in most discount online stores and a repair to the motor $99.00
Please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | Emson Magic Bullet Express Blender
Help me revive my dead Oster blender
Check the motor brushes. They may be worn out. Also, since the 1980s, many electric motors have a thermal fuse in them. This unit "blows" when it gets to a certain temperature.
This fuse looks like a 22-caliber bullet and its pointed end is usually colored. If you have an ohmmeter or continuity checker, see if current will pass through the fuse. If not, you can try to replace it. Most times, the fuse is attached with crimp-on connectors. Replacements can be soldered in, if you put a clip-on heat sink between the fuse body and the soldering iron.
Mar 09, 2008 | Oster 6854 14 Speed Blender
Magic Bullet Nutribullet Blender Logo
198 people viewed this question
Top Magic Bullet Blenders Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
R.A. Ellis
R.A. Ellis
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
