Question about Epson Office Equipment & Supplies
Epson wf2530 error code 0x7E - Epson Office Equipment & Supplies
3 Suggested Answers
  • 8 Answers
SOURCE: Following message appears when I try and play
uninstall the program and reinstall, if prompted to over write select yes. if that doesnt help it, go to this site and run a scan after you uninstall the program and after the scan reinstall
Posted on Oct 25, 2009
SOURCE: Toshiba Power Saver. Fatal error Code 0x7E
uninstal windows. install ubuntu, unix, door... whatever, but not windows.
Posted on Sep 18, 2013
Epson WF2530 All-In-One Communication Error empty ink levels when ink cartridges are full.
How long did you shut off the machine and computer? Some need at least one minute to lose the query. If you can, try another Epson cartridge and see if this is the problem. It literally can not find a full cartridge of ink. Take it out, reinstall it. Make sure it is the brand that you used to use, some don't have the same lead position. Hope it helps.
Sep 29, 2014 | Office Equipment & Supplies
When i try to install windows 8 appear code error:0x7E
Activate windows click here: www.acyberkey.com
you can find the keys you want in a low price that you have never imagined.
Jan 27, 2013 | Microsoft Windows XP Professional
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
uninstall Power Saver while in Safe Mode, reboot into Safe Mode again, and reinstalled Power Saver
Jul 05, 2012 | Toshiba Computers & Internet
Windows BSOD on all restarts, even in Safe Mode and even if I start with video in VGA mode. Stop code is 0x0000007E plus four more codes in parentheses. During Safe Mode restart the last file to appear on...
7E is a memory issue or general driver fault. It's windows way of saying "i dunno it just died". If you have Dell diagnostics, run a full system check, to ensure the hardware is ok. If you get no errors, then you have a driver fault in windows. This is From Microsoft:
If the following conditions are true, the issue might be a hardware incompatibility with Windows XP because all the installed drivers are Windows XP drivers:
  • You receive the STOP 0x7E error when you first start the computer.
  • You receive the STOP 0x7E error after you run the Setup program.
  • You did not install any third-party drivers during the installation of Windows.
However, if you receive the STOP 0x7E error after you upgrade from Windows 2000 Professional, or if you recently added a new hardware device, this issue might be an incompatible driver or an incompatible hardware device.
Basically, the 7E error is a defective driver. You will likely have to get your computer recovered by a professional shop, or if you have nothing important on it, attempt to reformat and reinstall. It is unfair that Windows has borked your computer and they wont fix it. I hope I was able to at least point you in the right direction.
Oct 26, 2009 | Dell Inspiron 700M Notebook
Following message appears when I try and play game: Couldn't load language resource dll Error filr Error code 0x7E (126) Any ideas??
Oct 24, 2009 | Microsoft Flight Simulator X for Windows
78 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
