Question about Garden
The drive belt on my Grazer 1800c went out, and I am unable to find the correct pattern for it. Any suggestions?
AIWA AD-F800 Replaced belts, old ones totally degraded. If I insert a cassette it will play but only play for 2 seconds (good audio out) but then it stops?
It is important to thoroughly degrease the pulleys before fitting the new belts and it also helps to remove some of the polished drive surfaces with some fine Scotchbrite.
It can also be the perfect time to apply a little light machine oil here and there with a precision oiler.
Finding new belts can be a problem. Most people left to their own initiative will select a belt that fits, often using the old belt as a pattern or by measuring. Unfortunately it is rare the correct size of belt will provide enough friction to drive everything successfully. As a general rule the square or round section belts of the right size must be stretched considerably in order to do the job. Even flat neoprene belts must be stretched by a large amount to fit and drive.
In the absence of knowing the correct size it is well to measure and guesstimate a suitable size smaller and then fit progressively smaller until satisfactory operation is achieved.
Apr 01, 2017 | Aiwa Audio Players & Recorders
Belt pattern.3 belts .taken off to replace water pump forgot how they went.
Search online for R&R belts for the year and make and model of vehicle and engine type you're working on. Example : R&R belts for a 1982 Toyota pickup 22r engine.
Sep 02, 2015 | Cars & Trucks
I just changed the drive belt on my 2007 mtd yardman and now I have very little speed any suggestions to the problem
If the belt is correct you may have wrapped the belt around a "belt keeper" that you didn't see and the belt is dragging on the keeper ,or the belt is not correct,or it was not installed in it's correct path.
Jun 24, 2014 | Mtd 46" Oem Deep Dk Drive Belt
My 1973 Yamaha RD350 has failed its roadworthy test because the headlamp focus has a dark patch at its centre when tested by the official headlight test unit. I have checked the lens pattern with the...
In the UK if it produces light and does not dazzle the oncoming cars, it passes.
Maybe it is the wrong drive side. Left hand in the right hand drive country is terrible light as it is the other way around.
Jul 04, 2017 | 1986 Yamaha RD 350
Serpentine belt keeps coming off
if it's a new,are you sure it's the correct one?(same amount of grooves),possibly your tensioner is bad or loose?(with the belt off,see if the tensioner,idler pulley,is/are wobbly),sure you have the correct installation pattern?(if wrong pattern,it'll surely come off) .Hope this helps. Alberto
Aug 23, 2013 | 1994 Plymouth Voyager
Stanton str8-20 belt size???
HI,
If you are unable to find your turntable measure the nearest length, if you are unable to find the exact length (as belts stretch slightly with use and age) choose the nearest shorter length. To check drive belt length for most type full platter decks remove mat and lift platter off center spindle (remove circlip if fitted), turn platter over and measure the circumference of the drive hub and deduct 5-10mm to determine correct length and tension
OK
Dec 11, 2012 | Audio Players & Recorders
Serpentine belt pattern, belt won't fit
A serpentine belt (also known as a multi-vee or multi-rib belt) is a single, continuous belt used to drive multiple peripheral devices in an automotive. ---------------------------------------------------------------------------
Car Diagnostic Tools
Dec 08, 2012 | 1989 Mercedes-Benz 300-Class
It keeps eating drive belts! It looks like the pulleys are not parallel. Can you align them? It appears to be spring loaded
Either the belt you are using is not the correct lenght and width, or one of your pulleys is worn out. Make sure that you are using the correct belt. Poulan mowers (made by AYP) will typically use a fractional length belt...meaning that you have to buy a Poulan belt to go on it. With the proper belt and pulleys, the front drive pulley should be level and the belt pattern should not contact anything other than the pulleys.
Aug 30, 2010 | Poulan Pro " Pro" Self Propelled Mower
1998 Dodge Avenger serpentine belt issue
What size of motor, do you have a/c and which belt are you replacing? Not sure about your engine size since you did not list it so please pick the applicable motor:
Sebring Coupe And Avenger (2.5L VIN N Engine)
  1. Disconnect the negative battery cable.
  2. Loosen the tension pulley locknut.
  3. Rotate the adjusting bolt to decrease the belt tension.
  4. Remove the drive belt from the engine.
To install:
  1. Position the replacement belt around the pulleys, making sure the belt routing is correct.
  2. Adjust the belt by rotating the adjusting bolt until the correct tension is reached. Refer to the procedure earlier in this section for belt adjustment.
  3. Once the desired tension is reached, secure the locknut. Recheck the belt tension.
  4. After the belt is installed and adjusted properly, tighten the locknut to 17 ft. lbs. (23 Nm).
  5. Connect the negative battery cable.
2.0 DOHC
Power Steering Pump And A/C Belt
To install:
  4. After the belt is installed and adjusted properly, tighten the locknut.
Oct 29, 2009 | 2000 Dodge Avenger
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
