Question about LG enV VX9900 Cellular Phone
LG ENV2 says Battery Required
Screen shows battery required despite the fact battery is in and appears charged. Phone will not power on.
  • jpla2001 May 18, 2009
    can't acccess USB.
    Battery is required on
  • 25 Answers
Sounds defective.
Posted on May 08, 2009
On power up, why does it indicate 'use genuine battery', then shuts off?
If your phone does not indicate it is charging, the 'use genuine battery' message may its way of telling you the battery is defective.
Nov 23, 2015 | LG VX8350 Cellular Phone
Bought new battery for cell phone, wont charge or turn on
did you try a new charger not the best solutinon
Jun 11, 2012 | LG Rumor 2 Cell Phone
I connect the charger to my lg env2 and nothing happens? Could it be the battery since the phone is about 3 years old. Maybe something internal.
It is most likely the charger port. They are cheap to purchase on E-bay, but require some knowledge of soldering to install it. What you could try is bending your charging wire back and forth, giving it a few seconds to respond. It may come on, then you have to hold the wire in that place while it charges. You can use a rubber band for this.
Jan 07, 2011 | LG enV2 VX9100 Cell Phone Car Charger
When i power on my lg vx11000 all that displays on the screen is (battery required) and the thing is the battery is fully charged and indeed attached to the phone correctly?? plz help
try to turn it off, remove the battery, then press the power switch for about 10 seconds. After that, connect the battery making sure the contacts are okay, then switch on the phone again and see how it goes. hope this helps and your rating/comment would be appreciated.
Oct 04, 2010 | LG enV Touch VX11000 Cell Phone
Low battery all the time
hello,
the fact that your battery indicates low all the time is as a result of either the battery or the phone.
to check if it is the battery, try another battery in your phone to see if it last longer,. if it does then the fault is from the battery and it needs be replaced.
to check if it is the phone, try another well charged battery in the phone to see how long it last. if it shows battery low on time, then the fault is from the phone. which is as a result of a problem on the board of the phone.
to solve that problem, it will require you to take the phone to an lg expert because it requires a careful and systematic process.
take care.
May 27, 2010 | LG Vu CU920 Cellular Phone
LG enV2 Battery not chairging
It might be your charger or your charger port.
First check the charger by using another charger to test if it will charge.
If not charging that means your charging port is faulty needs to be changed.
Jan 21, 2010 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
Lg env2 not charging
The issue is the charger port on the ENV2 breaks fairly easily.The first step is to contact your carrier to see if it is coveredunder warranty. If it is, great get it replaced.
3.You can get an external battery charger to charger the batteryseparate from phone. cost about 25 dollars. Check out the following linkfor ones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
Hope that helps
Aug 04, 2008 | Verizon Communications enV2 Cellular Phone
LG enV VX9900 Cellular Phone Logo
1,630 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
