Question about LG LSC27914
Will not eject ice - LG LSC27914
The Refrigerator's ice maker makes ice, but will not eject the ice. Have tried to reset the ice maker but will not eject, any ideas?
The ice maker has heater that thaws the ice cubes a little before they are ejected. This keeps the from sticking to the form.
Jun 26, 2015 | Kenmore Refrigerators
The ice maker stopped ejecting ice. Now no water going to icemaker
hav u cleared the ejection area for any debris and the like?
Jun 14, 2008 | Frigidaire FRS23H5AS Side by Side...
Our ice maker fills but
Defrost the fridge leaving it unpugget 48 hours, this may solve the problem
Apr 21, 2008 | Refrigerators
Diagnose GE Ice maker works makes ice! continues to eject ice when glass is pulled away in door
The switch is probably sticking. It may be the lever is sticking.
Oct 12, 2014 | Refrigerators
Ice tray won't eject ice
check the icemaker timer. replace with new if bad, thanks .
Aug 25, 2014 | LG Refrigerators
Ice maker won't eject icre
you need to replace the ice maker because the heater inside the ice maker is broken thats way its not ejecting the ice
Jan 18, 2013 | Maytag Refrigerators
Ice maker has stopped working.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 01, 2011 | Whirlpool Ice maker 4317943
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice maker will not eject ice cubes in GE Profile gss25tswass
Empty all ice from the bin and from the "Drill" like Ice shaper spinning unit. Let the unit make some new ice and see if that works.
Feb 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker is not ejecting the ice cubes
sounds like you have an issue withthe ice maker mold heater, not afield servicable part, replace the entire ice maker a assy, easy to do 2-3 screws and a wire harness
Oct 24, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
LG LSC27914 Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
