Question about Samsung P2770 27 LCD TV
Removing back Samsung 2770 HD
Pulled the coax fitting off, how can I remove the back of Samsung 2770 HD? only see five screws
5 Suggested Answers
  • 67 Answers
SOURCE: How do I remove the back panel from a samsung
Samsung LCD TVs has 12-16 screws that need to be removed before taking back off.
Dont forget the screws that hold the connection panel (SCART, HDMI, etc) and the bottom screws that hold the stand. These are screws i missed when i first opened my Samsung TV.
Good luck !
Posted on Jul 27, 2009
  • 11 Answers
SOURCE: lCD TV
There is more than two screws holding the back cover on. I think it is more like 4 to 6. After you have removed all the screws you will nee a flat screw driver to help pry the two halves apart. Be careful the front of the cover has little snaps that help hold the two together.
Posted on Mar 09, 2010
  • 119 Answers
SOURCE: how do you remove the
Yes, remove all of the perimeter screws, and there are some hard to notice screws by the video ports. Take your time when removing the back, if it doesn't want to come off, you are missing a screw.
Posted on Feb 27, 2011
gopakumarg43
  • 74251 Answers
SOURCE: How to remove external case of Samsung LTN1765, after 2 screws removed.
Hello
I've all the details for your TFT LCD monitor. It has all the details about its service, disassembly and reassembly methods [with illustrations], schematic diagrams, voltage charts, adjustments to chasis, voltage chart etc. But I can't send you that document by this site, as it does not allow me to upload PDF files by it. Moreover, acording to newly hoilsted FixYa site, I'm not allowed to send any PDF files to customers. If customer want to get it, he have to purchase one amoung my advertised service on FixYa.
So if you purchase one amoung Samsung service advertised on Fixya, I can send you all the documents by the link provides by Fixya between us. If you are interested, do the rest. OK.
Posted on Nov 24, 2011
Assembly instructions Hampton space saver
what you are showing there is the locking screw removed from the panel and locked where it should be
use a philips screw drive and turn the screw a half tun and that will allow the screw to be pulled from the panel shown
screw that screw into the corresponding panel and then put the panels together over the dowels and the screw that you removed and fitted just fitted will go back in where you took it from
hold together and turn the philips screw a half tun and it locks the panels together
all this is explained in the assembly instructions
Oct 24, 2016 | Dryers
Changing headlight bulb
remove 7mm bolts holding hd light , remove the five 10mm bolts,two clips and two philips hd screws on cover between hd light . then on bottom in front of front tire remove all plastic tabs and screws on wheel well lining . now you can get to a single 10mm bolt holding the hd light. hd light is ready to be removed.
Jul 12, 2013 | 2008 Saturn Aura
How do you replace a coax antenna port that was pulled out from the back of the tv
On most sets the tuner has to be removed for this to be done-a new fitting or a new tuner can be installed.
If the set has the standard RCA audio and video jacks for input you can hook a cable box or even an old VCR to those and BYPASS the coax fitting--hook up to those inputs--select them on the set and leave set on that input and change channels with the box or VCR.
Much cheaper than replacing the fitting and gives a better picture.
Apr 11, 2012 | RCA Televison & Video
Element does not heatup
I once had a similar problem with this electric smoker and i called Masterbuilt and they said they no longer sell the elements. you have to buy the cabinet @ $189 for the 40" model. I decided to pull my element and see if i could find one that would work by going to an appliance repair parts store.
When i pulled the element, i found that the terminal that plugs into the element was burned/melted in two. i replaced the terminal end, pluygged it in and it is working fine.
to remove the element, you need to remove the element cover/chip loading chute first. its easy, 2 sheet metal screws and 2 nuts and 2 machine screws. one of the nuts/machine screws is a little hard to get back on when you reassemble but it can be done. after the cover is removed, you will see 3 screws where the element goes through the back wall. only removed the left and right ones. do not loolsen or remove thecenter one. after you remove the 2 screws, you can coax a small amount of the wire leads out into the open and you can inspect them to see if they are broken.
if the problem is truly a bad element, you will have to find an element somewhere.
Sep 25, 2010 | Masterbuilt 20070106 Electric Smoker
How do I adust the emergency brake
There is an adjuster under the console. See instructions below from autozone.com:
    1. On vehicle with low series floor console:
    1. If equipped, remove the manual transmission shift knob by turning counterclockwise.
    2. Remove the floor console front finish panel.
    3. Apply the parking brake, then remove the floor console rear finish panel.
    1. On vehicle with high series floor console:
    1. Apply the parking brake.
    2. Remove the floor console finish panel.
    1. Remove the adjustment nut clip.
    2. Turn the parking brake control adjustment nut so that the parking brake control stroke is three to five notches when pulled.
      0996b43f80204da9.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Turn the parking brake control adjustment nut so that the parking brake control stroke is three to five notches when pulled
    3. Confirm the parking brake is applied.
    4. Install the adjustment nut clip.
    1. On vehicles with high series floor console:
      1. Install the floor console rear finish panel.
    1. On vehicles with low series floor console:
    2. Install the floor console front finish panel. If equipped, install the manual transmission shifter knob by turning clockwise.
  • Sep 12, 2010 | 2004 Ford Escape
    The attachment point for the coax cable was pulled off-broken off
    You'll need to take it to a repair shop. There are high voltage capacitors inside a television which will hold a charge even after all power is removed. I would highly advise against making this repair yourself.
    Dec 03, 2009 | Sharp 27H-S60 TV
    How to remove the front cover of my samsung front load gas dryer
    take the top off first by removing the two screws in the back, then the five screws which hold down the door section. the door will lift off and then follow the instructions
    Jun 08, 2009 | Samsung DV448AGE Gas Dryer
    I need to remove the antenna so i can remove my bags
    If you're talking about the FM antenna in the tour-pak, look inside and you will see a small screw on connector for the coax cable.  unscrew the coax and then pull it free from the wire guides on the floor of the tour-pak.  At the front left corner will be a large round rubber grommet.  Pull the grommet out and feed the wire out of the tour-pak.  The wire can be stowed behind the left side cover panel, where the fuses are.
    Jan 13, 2009 | 2003 Harley Davidson FLHTC Electra Glide...
    How to remove the stand from samsung LCD TV
    Place the tv on its screen flat on a soft surface,
    you need to remove all the screws, not just the stand one marked.
    Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
    Place all the screws back on the back lid.
    Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
    Samsung P2770 27 LCD TV Logo
    Henry  Thomas
    Henry Thomas
    Jerry Greenberg
    Jerry Greenberg
